H22/ k-series/turbo parts and motors.+accord parts
I have a lot of parts and motors I need to get rid of. Everything thing is plus shipping and 3% if paying with paypal. Prices are pretty firm. But if you have a resonable offer. Feel free to pm me. I don't get on here that much so feel free to contact me at 832-659-6637.
All parts are located in Houston Tx.
Stock obd-1 1994 h22a comes with what is in the picture. Intake comes with it but not installed.I have no idea on the miles on it. It has a stock clutch on it that goes with it also. $600
Rebuilt 1996 obd-2 h22a1. It has new bearings,rings,manual tensioner swap,all seals and gaskets. It has 0 miles on it since the rebuild I never installed it. This is an older pic of it on the engine stand. $800
Turbo xs manual boost controller. $55
JG-Fab H22 turbo manifold. 38mm watsegate flange. $200
ACT 8lb lightweight flywheel. Used for about 4k miles. $100
Hasport 94-97 accord h22 swap mount. $100
Magnaflow muffler used for about 2k miles. 2.25 inlet. $120
H22/F22 tapped oil pan for a return line. It comes with the fitting and my old return line that is not in the picture. $60
H22 88mm forged wiseco pistons 9-1 compression. Part #6544m88.Used but still in great shape. $300.
USDM OBD-1 P13 it has no speed limiter like the jdm ones do. $150 SOLD!
OBD-2a to OBD-1 adapter: $60 SOLD!
obd-2 H22 distributor: $80
Brand new 97 and up prelude throttle body cable: $15
94-97 accord front upper strut bar. Ebay brand. polished. $20
94-97 accord alternator works great: $80
94-97 accord power steering pump: $60
94-97 accord power steering line. High pressure side:$40
94-97 accord low pressure side line and factory oil cooler: $40
94-97 factory accord 5 speed shifter and cables. They shift like butter. No issues: $150
94-95 accord obd-1 internal coil distributor: $40
98 prelude stock clutch good condition:$10
3 oem f22/h22 flywheels good condition: $5 each
Kseries parts:
04 tsx cams. $150 SOLD!
04 tsx head. Complete minus cams and valve cover. $400
I have 2 ep3 tensioner setups with the roller and tensioner. $150 each
06+ civic si strup race header. $200 SOLD!
Tien S-tech springs and shocks of a 08 si. Only have the front shocks. Rears were bad. $300
Here is how they looked on the car.
Kseries parts:
06+ civic si strup header is SOLD.
For an extra $200 with either engine I will throw in a m2a4 transmission. Doesn't grind. Don't know the mileage on it. I will sell it by itself for $300.
