electronic speedo in cable trans?
Old May 21, 2011 | 11:16 PM
h23vtecDA's Avatar
Default electronic speedo in cable trans?
ive done some research but to no avail. I just put an ek cluster in my car and tryed fitting an electronic vss from a d series in my cable d series transmission and wouldnt fit.
only real thing i can find is someone modifing their vss with a 92eg and 99 integra top. something to that nature. I was just wondering if theres any electronic vss you could swap straight into a cable d series trans??
Old May 22, 2011 | 06:13 AM
D16SiHatch's Avatar
Default Re: electronic speedo in cable trans?
i'm using a 92-95 d-series vss in my 93 b-series tranny, and i didn't have to change anything to make it work. i want to say back when i did my swap someone had said that if you were using a d-series cable tranny that you would want to use a b-series electronic vss, but i'm not 100% on that.
Old May 22, 2011 | 01:25 PM
90civichbsi's Avatar
It should fit. Sometimes you just have to twist and wiggle it to get the gears to line up and let it slide in place.
Old May 22, 2011 | 02:24 PM
PHEDROTTO's Avatar
dude use the speed sensor of civic 96-00 with this one dont hit the rear suport and you can plug it nice!!!
that same happen to me with my old d15b.
thnks
Old May 23, 2011 | 03:45 PM
h23vtecDA's Avatar
I tryed a vss out of my buddies 98 ek. It was actually a little bit longer than my stock one and wouldnt fit in right. but I will try the b-series VSS and hopefully thatll work, not having a working speedometer really sucks lol
Old May 24, 2011 | 05:43 AM
PHEDROTTO's Avatar
yeah its longer and you will fit it with a 10mm large screw with a washer, so the washer push the hole of the vss and dont let him come out, got it??
Old May 24, 2011 | 08:40 AM
civic'x's Avatar
conoce perro....
Old May 24, 2011 | 07:15 PM
ef_cowboy's Avatar
so leme get this strait, all i gota do to get a electric spedo(not the bikini) is put a different cluster and sensor and thats it...were do the wires plug into..
JOE BD-0
Transmission & Drivetrain
Apr 28, 2011 11:39 AM
mugenwannabe
Sep 21, 2006 11:14 AM
cbp_crx
Jul 8, 2005 11:53 PM
SpeedMonkeyRacing
Jun 2, 2004 09:40 AM
johnzm
Aug 30, 2002 09:32 PM
