Skunk2 pro s coilovers
Old May 21, 2011 | 07:51 PM
domokun1521's Avatar
Default Skunk2 pro s coilovers
okay i just got skunk2 coilovers for my 1990 ef hatch and it didnt make me as low as i thought that it would and they are all the way down and i dont understand because this crx is dumped on the same set up!!! http://ll.speedhunters.com/u/f/eagam...x/IMG_3848.jpg
Old May 21, 2011 | 10:33 PM
BlendedEM1's Avatar
Default Re: Skunk2 pro s coilovers
I think that it mite be because of the top hats I think that you need to get longer ones if I'm correct I remember reading something on here about a guy wanted his Rex to be slammed as well do a search for not low enough and I think that mite pull up something
Old May 21, 2011 | 11:29 PM
BrandonR's Avatar
coilovers arent meant to "dump" your ride. And are you sure he's "dumped"? and not just an illusion from his 16" wheels and lip?
Old May 22, 2011 | 10:57 AM
jdm206's Avatar
i have the pro s coilover on my hatch and its dump. the front didnt go as low so i found a seller selling the st drop forks and it droped it alot more
Old May 22, 2011 | 01:15 PM
gringo7718's Avatar
Try this thread you started, in which all the answers you wanted were given - even pics.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/not-enough-low-2930991/
Old May 22, 2011 | 02:41 PM
sh1ntaox's Avatar
10 Year Member
https://honda-tech.com/forums/road-racing-autocross-time-attack-19/my-jdm-civic-ef9-track-car-2384170/
just for fun. possible setup to match. looks pretty tight. drool over this old post.
Old May 23, 2011 | 11:19 AM
usdmed9's Avatar
I had the same coilovers on a crx and now on a hatch and they are a lot lower on the crx
Old May 23, 2011 | 11:41 AM
do you know if you can compress the spring all the way up to the bottom of the black bump stop???
Old May 23, 2011 | 09:00 PM
usdmed9's Avatar
I'm not sure. I don't have a spring compressor to try it.
Old May 24, 2011 | 04:51 AM
Lol no the coilovers allow u to compress the spring up but it just gives you a stiffer rider
Old May 24, 2011 | 10:39 AM
usdmed9's Avatar
So you're saying to try to turn the collar all the way up, as if I were to raise the car all the way?
Old May 24, 2011 | 10:56 AM
Yes and that will compress the spring and then turn up smaller black locks to lock it there and then spin it back down, its a lot of work but that is how you get it to go lower http://www.youtube.com/watch?v=6eSpwEXwYlc
Old May 25, 2011 | 02:37 PM
usdmed9's Avatar
Turns out I'm an idiot and didn't pay attention to the "s" in the OP's post as I have the pro c 2 piece coilovers. . Thanks though, I'm considering upgrading to those now. I was originally commenting on it being weird that crx's can go lower than hatches with the same set up
Abius
May 21, 2008 10:31 AM
Richard.
Suspension & Brakes
12
Aug 16, 2005 03:07 PM
melvin
Aug 11, 2005 11:11 AM
Unjockable
13
Nov 8, 2004 02:27 PM
