Anyone here can translate this? Japanese diagram...
Here is a diagram for a pivot shift lite that I bought, its the one with a silver box and a small led light. I'm not sure what's the **** in the back of the box supose to adjust because the manual is in Japanese... here is the diagram. Anyone here can translate it for me. TIA
[Modified by KekeK-18, 3:52 PM 9/30/2002]
According to my limited Japanese, it says "RPM Detection Signal adjustment" It also says if it works fine, don't touch or turn the **** without consulting the chart!
The chart describes how to adjust it, with symptoms and solutions.
Looks like turning it left makes it more sensitive, right is less sensitive. Normally, it should be set to sensitive, and if the air conditioning or other electrical loads cause the lamp to misbehave at low rpm, you should adjust it slightly more to the right until it solves the problem.
[Modified by Gansan, 3:12 PM 9/30/2002]
Linked
15
Mar 4, 2010 07:40 PM
LSRracing95
Audio / Security / Video
10
Mar 23, 2006 06:47 PM
91_hatch_si
Jul 1, 2003 11:37 PM
