brake problem help?
so i have a problem with my brakes, there locking up to the point where i cant even move, i have new rotors and calipers in the front it takes like 10 mins of driving for the brakes to lock up i have da rear disk brakes. bled the brakes mulitple times and still stump with the problem
did you get new pads/rotors recently? I have noticed that some aftermarket parts companies are now selling rotors/pads that are beyond the spec of OEM equipment. for example, the OEM pad depth should be 9mm maximum, but I just got some pads from Advance auto that were 11mm deep. Now, throw on a brand new set of rotors that are in spec, and your brakes are 4mm/side more tight then they should be.
Get in there and start measuring pad depth and rotor width and report back with your findings. from there, you may have a vacuum booster issue if your brake parts are not incorrect against the spec.
elcid
Jul 25, 2008 11:04 AM
BigDare23
18
May 16, 2008 05:27 PM
wizzards581
16
Sep 17, 2003 06:16 PM
