Vibration between 40-60MPH
Old May 21, 2011 | 11:30 AM
NCMUDCAT's Avatar
Default Vibration between 40-60MPH
I bought my son a 1995 Accord EX. When holding steady speed between 40-60mph i get a vibration. If i shift down to d3 it goes away. Does not occur at higher speeds, even with cruise on. Any assist would be appreciated.
Old May 21, 2011 | 01:08 PM
kegobeer's Avatar
Default Re: Vibration between 40-60MPH
When was the last time you had your wheels balanced? That's a pretty common cause of vibration at a certain speed.
Old May 21, 2011 | 03:56 PM
75aces's Avatar
I have a similar vibration and it only happens when I hold the speed at 40. Mine sounds like it's coming from inside the engine but I don't have a cels. Can you feel it in the steering wheel? I feel mine in the accelerator.
Old May 22, 2011 | 05:48 AM
poorman212's Avatar
75aces-at 40mph your rpm's whould be around 1800~2100, correct?
Read about clogged egr ports and see if that describes the felling you are getting.
Old May 23, 2011 | 04:33 AM
NCMUDCAT's Avatar
Mine feels like its coming from engine/tranny also.
Old May 23, 2011 | 07:59 AM
StreetsideStig's Avatar
I wouldn't rule out wheel balance. It could even be tires, which was my issue.
Old May 23, 2011 | 08:49 AM
(. )( .)'s Avatar
do you have stock wheels, maybe after market wheels aren't centered?
Old May 26, 2011 | 03:48 PM
DJKhakiPants's Avatar
Wheel/tire balance would be the cheapest and easiest thing to eliminate... I had that problem on a volvo and it ended up needing new wheel bearings.
Old May 26, 2011 | 03:53 PM
eaperez209's Avatar
^x2 wheel bearing
Old May 28, 2011 | 09:22 AM
BravoOscar's Avatar
My '93 Accord has similar problem at slower speeds up to 40 mph, most noticeable 30-40 mph. Tires are only about 6 months old, so I don't think that's the problem. EGR, Differential, Transmission? Any thoughts would be most appreciate.
Old May 28, 2011 | 12:57 PM
75aces's Avatar
@poorman, at 40, the rpm band is between 1500-1800. What cleaning agent to use on the egr? When removed from the fuel rail, are there any gaskets to keep teack of? Also, is there any noise/indicators for bad wheel bearings?
Old May 29, 2011 | 05:09 AM
poorman212's Avatar
75aces- There is a write up in the FAQ that will help you. There is a gasket (EGR chamber)...is yours a 4 or 6, can't remember.
Have the tires rotated and balanced. Pull the front tires and check the bearings.
You said you feel it in the accel, that is why I was going there......
Old May 30, 2011 | 06:47 AM
Greg5150's Avatar
I had this problem on another vehicle and was pulling my hair out trying to find a solution. It turned out that one of the rims was bent but so slightly that the human eye could not detect it. Only when I used a dial gauge did I see that the rim was bent but a few thousands of an inch. I replaced the rim and the problem is gone.
Old May 30, 2011 | 09:12 AM
75aces's Avatar
@poorman, I have a 4cylinder. I had the tires balanced and rotated. The vibration only occurs at 40. For some reason it's only at 40, not before or after. Still trying to find the egr on the fuel rail, but I have no idea of what it looks like.
Old May 30, 2011 | 09:28 AM
poorman212's Avatar
The valve is at the back, dist end.
The port chamber is "under" the fuel rail.
http://www.freewebs.com/hondadude/95...5AccordEGR.htm
Old May 30, 2011 | 01:27 PM
FRISBEE's Avatar
When the inner cv's go out they can also have that vibration issue.
Old Jun 1, 2011 | 12:32 PM
75aces's Avatar
@firsbee, the vibrations aren't in the steering wheel. It occurs while accelerating from a dead stop. I had the tires balanced and rotated. If i recall, the cv joints will vibrate heavily closer to 70. I don't have that issue.
Old Jun 2, 2011 | 02:56 PM
poorman212's Avatar
75-wait now it starts "while accelerating from a dead stop"??? Way different answer if that is the case.
Old Jun 2, 2011 | 03:22 PM
75aces's Avatar
Yes that's correct poorman. From dead stop to 40.
Old Jun 2, 2011 | 06:34 PM
kegobeer's Avatar
Is it a vibration or a shudder? A shudder during acceleration can be caused by a worn inner CV joint, which means replacing the axle. A vibration that happens at different speeds can also be from a bad axle.
Old Jun 2, 2011 | 07:50 PM
75aces's Avatar
It feels like a shudder. It only occurs when I maintain a speed of 40. It doesn't happen on the freeway or as I accelerate. It's the weirdest thing. Thanks.
ektomee
13
Oct 17, 2013 08:07 AM
BDB_LV
Feb 16, 2013 11:26 AM
jim109
Aug 1, 2006 08:47 AM
SIMATIC
Sep 10, 2003 08:19 PM
