Wierd coolant bubbling problem...
Old May 21, 2011 | 06:12 AM
UNDER PRESSURE's Avatar
Default Wierd coolant bubbling problem...
My moms car is having a wierd problem, I've just recently replaced the engine with another one. While the engine was out I also replaced the water pump, timing belt, tensioners, and balance shaft belt. Now here's the problem, after a long drive the coolant overflow tank starts bubbling like it's overheating but the temp gauge needle doesn't even go up half way.
Could it be that the coolant system might have air pockets?
Can anybody point me in the right direction as to what it might be?
Thanks.
Old May 21, 2011 | 06:20 AM
poorman212's Avatar
Default Re: Wierd coolant bubbling problem...
Yes, that would be the first thing to check.
Then knowing what year the car is would help.
Old May 21, 2011 | 06:36 AM
I'm sorry it's a '96. I'm also gonna run out and buy a new radiator cap right now.
Old May 21, 2011 | 07:15 AM
poorman212's Avatar
That would be a cheap thing to try. Also when you bleed, be sure the heater is set to max, being sure to get any air out of the heater core.
Old May 21, 2011 | 12:19 PM
koo, thanks for the tip.
dvsblack
Apr 29, 2018 08:18 PM
cybernetictoast
Dec 30, 2012 02:12 PM
Doylerules4588
11
Jul 3, 2008 08:01 PM
Utilitarian
Sep 14, 2007 11:20 AM
redinferno2
Dec 2, 2004 07:01 AM
