Re-assemble F22A1 Short block
Old May 21, 2011 | 04:46 AM
supracord's Avatar
Default Re-assemble F22A1 Short block
Does anyone know of a post that shows the order in which an F22A1 bottom end should be put back together again? I have looked for two days before posting this and have yet to find anything. I took the block to a shop for new pistons, rings, etc and did not remove the oil pump, balance shafts, tensioners, etc, thinking the shop would put all that stuff back after they removed it. They didn't, (and won't...even for a price) and now I have a box full of nuts, bolts, gears, clips...you get the picture. Had I known this was going to happen, I would have used hundreds of zip lock baggies, marked every nut and bolt, and taken tons of pictures. Figuring out where everything goes isn't my biggest problem, (thou it is a bit of an issue) but the order in which I should put this stuff back seems to be elusive to find. Thanks for any help/direction you can give me.
spoolin414
Dec 28, 2012 07:03 PM
shrirag
May 14, 2007 04:25 PM
Project92Hatch
Oct 24, 2003 07:37 PM
sgT
Jul 4, 2002 08:31 PM
justagsr
Apr 17, 2002 06:28 AM
