How To: Summit RPM Switch?
Old Sep 30, 2002 | 11:14 AM
Jeff_G's Avatar
Default How To: Summit RPM Switch?
Is anyone here running a summit rpm switch to activate vtec for their d16z6? I just ordered one so my z6 will be able to make full power, but i have no idea on how to hook it up. I know i need to purchase a relay, but i dont know how to do any of it. If anyone can help me out, i would greatly appreciate it! Thanks before hand, Jeff.
Old Sep 30, 2002 | 11:57 AM
SOUTHCREX's Avatar
Default Re: How To: Summit RPM Switch? (Jeff_G)
On the rpm switch you hook the black wire to a ground,red wire to a switch 12v ignition,white wire hooks the the blue wire on the dizzy, then the yellow wire hooks to #86 on the 30 amp relay. that's all the rpm switch wire's, next you will have to finish wiring the relay. #30 on the relay gose to the battery, fuse it also.#85 hooks to a 12v ignition switch. last 87 gose to the vtec solenoid. the 87a on the relay is not used.
87---- vtec noid
86---- yellow wire (rpm switch)
85---- +12v ignition switch
30----- +12v battery (fused)
[Modified by TEAM GARAGE SHIFTDOWN, 9:03 PM 9/30/2002]
[Modified by TEAM GARAGE SHIFTDOWN, 9:05 PM 9/30/2002]
Old Sep 30, 2002 | 12:14 PM
RenoRacing's Avatar
Default Re: How To: Summit RPM Switch? (TEAM GARAGE SHIFTDOWN)
that sounds about right, i have a module selector too rather than a pin so i can adjust it anywhere from 4600 to 6800 with the turn of a ****, it's really nice.
Old Sep 30, 2002 | 01:35 PM
Ham'ed Hatch
Guest
Posts: n/a
87---- vtec noid
nice write up
boostedb20z
Mar 23, 2009 05:59 PM
tub_sephiroth
May 9, 2007 07:35 PM
FGride
Audio / Security / Video
Apr 26, 2006 12:43 AM
Simple
13
Jan 10, 2004 07:57 AM
stingray2772
Jan 6, 2003 10:23 AM
