ATTN: MISTABONE
Old May 20, 2011 | 01:08 PM
drtysoufchevy's Avatar
Default ATTN: MISTABONE
My cuz JDM_SOHC told me to hit you up bout a ?. Is it possible for my ISB(input Shaft Bearing) to make my tire shake? but it dont make any noise
Old May 20, 2011 | 01:16 PM
dem0nk1d's Avatar
Default Re: ATTN: MISTABONE
what the hell
Old May 20, 2011 | 01:47 PM
grumblemarc's Avatar
The Grumpiest
Private messaging. Learn to use it.
Old May 20, 2011 | 02:14 PM
EJ8_Man's Avatar
Old May 20, 2011 | 02:15 PM
JDM_SOHC's Avatar
He's asking for help, but specifically something I figured Bone would kno sum about lol... Instead of bickering on what he coulda/shoulda done, why don't you contribute by trying to help solve his issue, since this is a tech site...
Thanks..
Old May 20, 2011 | 02:27 PM
The Grumpiest
How about a little more info per the forum rules? A little more back story even? Like how you came to the conclusion that the ISB was causing the shaking? This is a tech forum after all.
Old May 20, 2011 | 02:31 PM
JDM_SOHC's Avatar
I'm happy you brought up the "forum rules" because if you would have practiced what you preached you would have saw he posted a thread asking for help before and didn't get much help.. Of course you would have had to search to do that, but of course you knew that, I mean with this being a tech forum with rules and all...
Searching could have perhaps saved you a few keystrokes..
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/passenger-tire-shakes-2929916/
Thanks again...
Old May 20, 2011 | 02:38 PM
The Grumpiest
So he ALREADY had a thread going but started this one as well? Why would I think of searching for an existing thread when someone asks for help? And many people tried to help him so saying he didn't get much help is incorrect.
Old May 20, 2011 | 02:44 PM
tlarimer's Avatar
Back on topic, before this gets into a cyber D$#k measuring contest
apexi_rsx's Avatar
The symptoms of isb going bad is a clicking noise in neutral with the clutch out. Whenpushing the clutch pedal in, the noise slowed down and stopped. so obviously ur problem is not the isb that is more clutch engaging issues. u may have a bent rim,out of balance wheel ( wieght flew off or fell off causing it to be unbalanced) or u have flat spots on ur tires.
Old May 20, 2011 | 02:45 PM
NOFX's Avatar
H-T White Ops
Woah... never heard of that before.
If you want to talk directly to one member though, it's often helpful to find their profile and then contact them from the PM option (under Contacts) there.
Here is Mista Bone's profile.
Making a thread about tech issues can often reveal more insight than just that one person might be able to though.
I'll report your first post so a moderator can edit the title so you stop getting negative attention.
Old May 20, 2011 | 02:49 PM
The Grumpiest
Two site I've looked at have said pretty much this "could be the drive shafts or the carrier bearing on the passenger side shaft. "
Old May 20, 2011 | 02:57 PM
JDM_SOHC's Avatar
Thanks for the help bro, an NOFX you're always beneficial..!!
Nick, you'll get the proper help soon man now this message is getting directed to the right people..
Old May 20, 2011 | 03:23 PM
94EG8's Avatar
Seagull Management
OP, please PM Mista Bone or post a thread with some actual tech content.
2000em1boycivic
Sep 5, 2010 07:51 PM
Ricey McRicerton
148
Jul 20, 2005 07:14 PM
madman604
Oct 25, 2002 09:19 PM
