FS: Turbo Stuff, RC, SARD, Tial, Garrett, GM, UPDATED DAILY!!!
From: Sin City to CA, to TX, NC to FL, then back to NC...
Here's a bunch of turbo items that could start you off. I'm finally done being turbo'd and having any turbo items in my possession, and I want to get rid of any temptations of going back. First things first, I was a huge SARD fan... So that explains why I have so much of it. If you don't know about them, GOOGLE it! They're a very solid Japanese company that tends to support the turbo community (expensive shiz!). It's very hard for me to let go of these parts since I spent a decent amount of time collecting all SARD products. So I hope it goes to a good owner who truly appreciates them. Call/text 702.979.0391 or PM if you're interested in any of my parts. I will only accept cash for pick up, but PayPal if I need to ship the item to you. I'm located in JAX, thanks.
-TJ
Turbonetics Turbo (needs a rebuild), will come with a RevHard B-Series cast manifold (a/c compatible) made 352whp on 15psi on my stock B16!! ---- $150
PIT 40mm wastegate w/dumptube (8lb spring) ---- $120
Turbonetics Turbo, RevHard Manifold, PIT Wastegate together (a/c compatible, need to trim condenser fan to fit) ---- $250
---- SOLD ---- to JD (craigslist.com)
GM 3 Bar Map ---- $30
99-00 Civic Fog Kit (lens painted yellow, covers painted milano red) ---- $30
Radiator Fan ----$10
RevHard Intercooler ---- $100
EK Charge Pipes (clears fogs for 99-00 civic!!), will not come with SARD BOVs ----$60
SARD Racing Blow Off Valves, left BOV has slight tear on diaphragm. I prefer to sell both together. ---- $100 ea / $150 both
- RevHard Intercooler and EK Charge Pipes together w/o BOVs $140
- EK Charge Pipes and the SARD BOVs together ---- $210
- EK Charge Pipes, Sard BOVS, and Intercooler ---- $280
SARD Racing Type C II Waste Gate (needs new diaphragm to be controlled for boost, but holds at 6psi) ---- $150
NEW EK Blox Dual Guage Pillar Pod ---- $20
EK Dual Guage Cluster Pod (60mm) ---- $20
DC Integra custom glove box (60mm), hides inside or floss it! ----$30
SAMPLE
SARD Trigger Boost Controller (missing actuator box) ---- $200
---- SOLD ---- to member WHCHUA (zilvia.net)
SARD EGT Gauge (needs new heat sensor) ---- $20
SARD Turbo Timer ---- $50
Garrett t3/t4 57 trim Stage 3 Wheel Turbo, made 382whp on 15psi with my B16! (needs new seals) ----$350
Blox B-Series Cast Manifold ----$130
3" Stainless Steel Downpipe with flex pipe (T1 Race Development custom made) ---- $80
3" Stainless Steel Testpipe (T1 Race Development custom made) ---- $30
3" intake for turbo short ram/cold air. Made to fit 96-00 Civic with RevHard Cast Manifold or Blox Cast Manifold (T1 Race Development custom made) ---- $60
Blox Manifold, Garrett Turbo, 3" DP, 3" TP, 3" Intake (will include return line to pan) ---- $550
---- SOLD ---- to C Poindexter (craigslist.com)
Couplers ---- $3 each
---- SOLD ---- to anti tyler (zilvia.net)
P2T ECU ---- $40
Rising Rate Fuel Pressure Regulator ---- $10
Charcoal Canister ---- $5
Tsudo 2.25" inlet Muffler ---- $10
Datsun 280zx Momo Hub ---- $50
-TJ
SAMPLE
P2T ECU ---- $40
bump for updates, PENDING SALE ---- Sard Boost Gauge, Sard Fuel Gauge, all T Bolt clamps
GregUnit
May 10, 2009 01:56 PM
JDMCRX
Sep 6, 2003 11:11 AM
