Oil in the intake side of cylinder head
Old May 18, 2011 | 11:17 PM
Paul-eg's Avatar
Default Oil in the intake side of cylinder head
Hey,
I have my brand new b20v up and running and it was burning oil and smoking a bit after break it. Compression test results are 250 in all four cylinders and when we did a leak down test all cylinders had between 0-2% leak down. Everything on this end seemed to be good so we pulled the exhaust/intake manifold off. Exhaust side was dry and the intake side had oil in it and cylinder number 4 seemed to have the most. The cylinder head was just reassembled with new everything including super tech valve seals and the motor has about 750km on it. I also have a catch can from the back of the block to a vented can. Does this sound like seals and if so what could cause them to go so quick?
The basic rundown of the set up is:
84.5mm JE 12.5:1 pistons
DNR ported GSR cylinder head
Supertech springs and retainers
Supertech .5mm oversized flat valves
Supertech valve seals
Skunk 2 pro 3's
Old Jul 6, 2011 | 06:44 PM
PreClude's Avatar
Default Re: Oil in the intake side of cylinder head
Bump. Did you ever figure this out?
Old Jul 6, 2011 | 07:14 PM
tempsohc's Avatar
if you are still running the oem pvc. This is normal especially on high comp engines that are revving high. The OEM pvc has a hard time seperating oil/gas vapor and sometimes recirculating liquid oil back into the intake manifold. correct me if i am wrong.
ek.troy
May 7, 2012 03:03 AM
Paul-eg
28
Sep 1, 2011 08:33 PM
charlie_sohc
May 1, 2006 06:08 AM
SiRkid
Jan 4, 2005 06:34 PM
