d15b vtec y8 manifold what gasket should i use???
Old May 18, 2011 | 05:28 PM
ej8bori89's Avatar
Icon2 d15b vtec y8 manifold what gasket should i use???
i have a 96 civic runnin a d15b vtec and my intake manifold is off a y8 and well its leakin air bad thru the top part of the manifold between the head and the manifold if its not cracked praying to the God what gasket should i use???? THANKS
Old May 18, 2011 | 07:23 PM
jbob50's Avatar
Default Re: d15b vtec y8 manifold what gasket should i use???
if the intake is of a auto. i would check for 4 or 5 holes into fuel injector holes block or weld closed.this worked for me. d16y8 2000 civic.after 5 try. LOL
Old May 18, 2011 | 07:47 PM
apexi_rsx's Avatar
i used rivets to plug mine u can leave them or grind them flush its a clean look. then cap off the top nipple thats mounted on the flange. i had this same problem when swapping my y8 edelbrock manifold on.
Old May 18, 2011 | 07:52 PM
ej8bori89's Avatar
its a five speed gasket was busted pretty bad i used a y8 manifold but some how its leakin outta one spot but barely....smh what did you mean about the injectore inside the manifold or outside..???
Old May 18, 2011 | 08:45 PM
apexi_rsx's Avatar
gaskets between manual and auto are no different. heres a DIY how to plug them or to check whether u have them http://www.d-series.org/forums/diy-f...-manifold.html
Wrona
25
Apr 21, 2011 12:27 PM
racingant
May 2, 2005 09:18 PM
mr. carpenter
Apr 20, 2005 07:28 PM
DrRice
Jan 9, 2005 10:19 AM
