1993 Honda Del Sol "S" clicking noise @ steering column
Old May 18, 2011 | 04:05 PM
Benito89's Avatar
Icon3 1993 Honda Del Sol "S" clicking @ Ignition Area w/o KEY!!!!!
Hello,
Introduction:I have a 1993 Honda Del Sol, with a 1997 Acura Integra GS-R swapped in. I had a situation regarding my wire harness and my swap. You can check out the thread at this link---vvv
https://honda-tech.com/forums/showth...+Honda+del+sol
After solving my problem I ended buying a subharness. (www.Rywire.com) I continued to install it ASAP, and because I have big hands I tried to remove the dash in my Honda del sol "S" to ease my access to the firewall . I removed all the bolts and proceeded to attempt the removal of the dash. Which was a failure because the dash just wouldn't leave the steering column...
The Climax: My girlfriend came by to check up on me and try to lend a hand. I then realized she had small enough hands to reach behind the ac condensor to thread the sub harness through. She ebnded up doing that for me. I then wired and cleaned everything up and bolted back the dash.
The Problem: As soon as I tried to ground the battery I started to hear clicking noises coming from the steering column/ ignition switch area, WITH NO KEY IN THE IGNITION! and I'm assuming I accidentaly added power to a solenoid, or pulled a wire out from somewhere whilst attempting to remove the dash from the steering column.
The search for a solution: What would be possible causes to this clicking noise? And if anybody could help; I'm looking for pictures and wire diagrams to the ignition switch and anything relating the switch to the Ecu. Thanks in advanced to all and any help!
4gen5thtime
Mar 24, 2009 01:44 PM
90dteg
Oct 9, 2008 04:25 PM
sir2sol
Oct 31, 2006 09:36 PM
delspool
Dec 9, 2005 05:00 PM
ckdelsol
Audio / Security / Video
Nov 11, 2001 07:28 PM
