VC wrinkle paint: baking in your oven stink up your house?
Old May 18, 2011 | 10:44 AM
creed86's Avatar
Default VC wrinkle paint: baking in your oven stink up your house?
Hi Paint & body:
Quick question. My VC is in desperate need of some fresh paint. So my question is when you stuck in the oven, did you stink up your house? If so did it linger, open windows help? Any thought, advice, and experience would be much appreciated. TIA
Old May 18, 2011 | 11:27 AM
Hawkze_2.3's Avatar
Default Re: VC wrinkle paint: baking in your oven stink up your house?
There's no need to put paint in the oven.
Old May 18, 2011 | 02:36 PM
creed86's Avatar
Oh most DIY i've read suggested it. Whats the right way to dry/cure it? overnight? let the engine heat bake it?
Old May 18, 2011 | 03:11 PM
96dxB16's Avatar
Just use the VHT wrinkle spray paint.
Old May 18, 2011 | 03:57 PM
creed86's Avatar
thats what I plan on using. Doesn't the instructions on the side recommend curing it in the oven?
Old May 19, 2011 | 02:28 PM
96dxB16's Avatar
It does, reading > me.
Says you can also cure by engine heat.
Old May 19, 2011 | 05:45 PM
91efbluehatch's Avatar
i cured mine by engine heat.
put a good couple of coats on, degreased my engine bay, and put it on. made sure there were nothing that would inhibit the curing.
i just spent the whole day cruising, and still have no problems with it to this day.
Old May 22, 2011 | 10:01 PM
Preezy's Avatar
I put all my valve covers in the oven after being painted with the VHT wrinkle paint. I've let them air/engine dry and the texture doesn't tighten up the way it does if you were to put it in the oven. There is a decent amount of smell when doing it this way, but by opening a few windows or doors it's not that bad. The smell also doesn't linger for very long either.
Old May 22, 2011 | 11:18 PM
kingofbattle909's Avatar
smarter way
Old May 24, 2011 | 04:25 AM
2ltrgsr's Avatar
be careful because that stuff didn't wrinkle evenly for me....
Old May 24, 2011 | 01:11 PM
sc34dc4's Avatar
I've done 4 valve covers now using VHT wrinkle black. I use the aircraft paint stripper to get them to bare metal. Then just spray that stuff off with a hose. Blow it dry with an air hose. Tape up plug holes and what not. Cut a piece of cardboard just barely bigger then the valve cover and sit it on there. Do 3 even coats of vht. Then stick it in the oven for 30 minutes @ 300 degrees. Yes it does make the house smell pretty bad. Open windows and doors to help out. It does stay around for about a day. Mine have all come out like oem with no issues.
Old Sep 7, 2012 | 02:29 PM
meo23's Avatar
I just want you to know... I specifically made an acount on this website to call YOU (Hawkze_2.3) a F'ing idiot..... I dont even own a hona and probably never will.
There is a specific need to bake items after being painted. it hardens the surface and binds the paint making it one whole piece instead of little shitty paint chips stuck together... so now you can actually press your hands and nails against it just like a car and not have it chip or crack....
God I hate ignorance..
Old Sep 9, 2012 | 03:56 PM
Ziprock's Avatar
i found when using this stuff that you have to really pay attention to laying it down evenly to get it to wrinkle evenly.
Old Sep 9, 2012 | 04:30 PM
Tony M.'s Avatar
This. 3 heavy coats, about 10 minutes apart from eachother will do the trick.
As stated you need to apply in evenly, and dont be shy to put enough on. You have to give it 3 heavy coats.
Hi Paint & body:
No, do as I said, and let it air dry for about 6 hours. DO NOT put in the oven, you have to let it wrinkle on its own. After about 6 hours of air drying put it back on, and let the engine heat from normal drving around finish up the curing.
Old Sep 11, 2012 | 09:20 AM
jdmcx's Avatar
i "cured" mine with a halogen shop light came out looking OEM only took an hour or so if i remember.
Old Sep 13, 2012 | 10:38 PM
evilclown312's Avatar
One weird curing technique i have seen is someone using a box, to trap heat, with a heat lamp for a long period of time.
Old Sep 15, 2012 | 05:44 AM
ej1 rep's Avatar
use a heat gun! then you can pinpoint the spots that may not be wrinkling good
Old Sep 15, 2012 | 08:23 AM
highroller54's Avatar
my wife wanted to burn me with gas for useing the oven, now i use a heat gun, works perfect.
Old Sep 19, 2012 | 10:48 PM
BroliaJDM's Avatar
lol macco! jk
vyrus
Apr 9, 2013 03:11 AM
bboysake
Paint and Body
12
Sep 4, 2010 04:15 AM
G'd_up
Honda S2000
May 12, 2005 01:15 PM
kay_animation
May 21, 2002 11:07 AM
