Front End Damaged EG (pictures)
Old May 17, 2011 | 10:52 PM
Dontoh's Avatar
Default Front End Damaged EG (pictures)
so I'm in the middle of repairing/tucking/shaving my front end.. my core support is pretty beat up, along with the corner of the passenger side of the car right infront of the motor mount (pictures below).. its basically the side of the core/rad support.. im just wondering how much work it would be to drill out the spot welds and weld a new one in.. and if its not so bad, where in the world would i find one?
Old May 17, 2011 | 11:02 PM
BrownDx's Avatar
Default Re: Front End Damaged EG (pictures)
Replacing a core support isn't too bad. I had zero experience and I did it on my girlfriends car after she had hit a deer. I went to a junk yard and got an entire front end, removed the support and welded it back on. You could always get one from Honda or even an aftermarket one.
Old May 17, 2011 | 11:08 PM
BrownDx's Avatar
Looks like you may be able to get the area under the shock tower at Honda, # 10.
Old May 18, 2011 | 05:34 AM
Dontoh's Avatar
ive been looking for a diagram like that for awhile^.. thats what I was hoping for. I think I'll need 8 and 10
Old May 18, 2011 | 05:43 AM
kaiba's Avatar
hondaautomotiveparts.com or your local dealership/part can print out a diagram.
Old May 18, 2011 | 05:40 PM
EGcivic_95's Avatar
from the looks of it, its the right side front apron amd core support and its farly easy to fix
Old May 19, 2011 | 08:19 AM
Dontoh's Avatar
progress yesterday, wish me luck
Old May 19, 2011 | 10:46 AM
BrownDx's Avatar
You've got it. Excited to see how it comes out.
Old May 19, 2011 | 01:54 PM
Fibercation's Avatar
now just spot weld/grind and use some seam sealer and your good to go
Old May 19, 2011 | 05:30 PM
Dontoh's Avatar
and today :p.. lotsa drilling
it's so hard to believe that this thing actually (and will) run at one point
Old May 19, 2011 | 07:02 PM
BrownDx's Avatar
Haha, it's funny how you start to think those thoughts after the car looks like it belongs in the junk yard. I have been there a few times myself.
Old May 19, 2011 | 08:53 PM
Dontoh's Avatar
yeah, just the fact of building it up from literally bare frame to a fresh paint job. and from control arm bushing to the valve cover.. its just crazy haha
Old May 20, 2011 | 10:43 PM
BrownDx's Avatar
Build it once the right way, the way that you want, and then drive it. That's the best way!
Old May 21, 2011 | 06:20 PM
prelude1897's Avatar
good stuff so far...I've done a couple of front end repairs. It's definitely time consuming, but you're be happy once it's all put back together
Old May 21, 2011 | 08:34 PM
Dontoh's Avatar
yeah same, but nothing more than cutting the core support out and re-welding a new one in. did this to my buddies last month
this
to this, in sub 10 hrs
Old May 23, 2011 | 09:08 PM
BrownDx's Avatar
Have you made anymore progress?
Old May 23, 2011 | 09:31 PM
Dontoh's Avatar
still waiting on my core/rad support to come in from keystone. i did however get that #10 piece mocked up.. i'll post a couple pictures after im done changing my fishtank substrate :p
Old May 24, 2011 | 06:27 AM
kyden's Avatar
not sure if this applies to you, but all the aftermarket radiator supports i've seen are complete junk (metal too thin for the jack point). also bumper beams being half as thick as oem.
Old May 24, 2011 | 07:21 AM
Dontoh's Avatar
Thanks, but I've never had a problem with keystone, and I've done quite a few collision repairs using their parts. They are all CAPA approved (tested to fit like oem, not that it means much) and Honda want 350+ for the support, I was able to get it through a friend of mine for 159, so I couldn't pass it up.. I usually don't jack from the core support anyway, it's not made to be used as a jackpoint
Old May 24, 2011 | 07:27 AM
Dontoh's Avatar
Old May 24, 2011 | 08:37 AM
kyden's Avatar
splitting hairs here i know, but it is indeed a jack point. look in the manual.
Old May 24, 2011 | 11:25 AM
Dontoh's Avatar
ahh, you're probably right, never actually checked. i just always assumed it shouldn't be jacked from there cuz its like tin, and its all held on by tack welds no bolts.. i jacked up a geo metro from the core support once and it bent so i never used it again..
oil pan all day
Old May 24, 2011 | 03:32 PM
DC209's Avatar
good progress man keep it up
Old May 24, 2011 | 04:40 PM
BrownDx's Avatar
Coming out nice, good as new! Honda makes it so easy to fix panels. What are your other plans for the car?
Old May 24, 2011 | 08:39 PM
Dontoh's Avatar
thanks bud
thanks man, its appreciated it.. as of now, i'm just trying to get it running, but since the motor (b20 block gsr head/trans) is out of it, I'm going for a full shave/tuck.. i've got school coming up soon, and this will be my only car, so it's going to be a daily driver. it'll be tucking tire with full disc brakes and brand new energy suspension ALL the way around. after i'm happy with that stuff, i'll be ripping my quarter panels out (again) and will be doing a full paint job (this hatch was painted at exactly this time last year).. i'm undecided on a color, but it's probably going to be a grey or dark silver.. or maybe that green tea color off the new crvs, i saw one the other day at the dealership and fell in love
