skunk2 cams on type r valve train??
Old May 17, 2011 | 06:54 PM
89si-lsvtec's Avatar
Default skunk2 cams on type r valve train??
i was wondering if i can get away with skunk2 stage 2 tuners on 01 type r dual valve springs & retainers?? thanks 4 replies
Old May 17, 2011 | 08:13 PM
SJC's Avatar
SJC
Default Re: skunk2 cams on type r valve train??
gunna say no on this one. best to go with skunk2 or supertech springs and retainers. get cam gears and a timing belt while your at it
Old May 18, 2011 | 09:54 AM
1998GsRIntegra's Avatar
I think the most you can get away with would be a tuner 1, but you still risk floating a valve a higher rpm. I would not recommend running any cam other than a stock itr on stock itr valve springs.
Old May 18, 2011 | 10:23 AM
FULLYBUILT2.0's Avatar
No! Its not safe... im sure you can run them but long term, oem itr valve train is not made for that of aggressive shafts! GL
Old May 18, 2011 | 10:57 AM
Tootsie7944's Avatar
Get Ferrea and do it right.
hovic
Apr 29, 2009 07:47 PM
RMXmitch
10
Sep 16, 2007 05:29 PM
vinasity
Jun 21, 2004 04:27 PM
Skunk2_92gsr
Feb 4, 2003 12:42 AM
marc.ejay-twenty
Feb 3, 2003 05:52 PM
