CEL's reoccuring
Old May 17, 2011 | 04:03 PM
KingDakota12's Avatar
Default CEL's reoccuring
Ok so about a month ago I have a few CEL codes and most of them were misfires so I did the normal thing and I replaced my spark plugs, spark plug wires, distributor cap, and coil pack.
After that the car ran fine and the CEL stayed off. Now Im starting to notice my car is not catching when I accelerate in 3rd, 4th or 5th gear and takes a second or two before it does and right after that my CEL came on.
Codes ran: P0302, P0304, P0300, P1399. All which are typical misfires I had before. What else can I do to fix this issue, I spent so much replacing all the parts named above and since I replaced the coil pack and dizzy cap I hope I don't need a new distributor?
Old May 17, 2011 | 05:50 PM
Default Re: CEL's reoccuring
Anyone?
Old May 17, 2011 | 05:52 PM
grumblemarc's Avatar
The Grumpiest
Check your timing?
Old May 17, 2011 | 05:57 PM
Nope I never did that? Easy or hard?
Old May 17, 2011 | 07:44 PM
Former User's Avatar
Did you replace the rotor?
Old May 17, 2011 | 07:46 PM
Yes Rotor was replaced.
Old May 17, 2011 | 07:51 PM
I read somewhere that a bad alternator belt can do this? Because next week Im replacing all three of my belts excluding my timing belt because they are old, worn and squeal, anything?
Old May 17, 2011 | 08:43 PM
Have the ICM tested.
When was the fuel filter last replaced?
Old May 18, 2011 | 08:56 AM
Fuel filter has probably never been changed. So replace that and check my ICM?
Old May 21, 2011 | 05:05 PM
Ok so i replaced the Fuel Filter today with an Autozone Duralast one. The CEL has not come on since I cleared the first one, but my car is idle at almost the bottom line roughly around 100-200RPM's tops at an idle.
Is there a way I can test my ICM or should I just replace my old one? With some research it looks like if I had ICM problems my car would more stall and have trouble starting than the rough and low idling and misfires?
Old May 21, 2011 | 07:09 PM
Anything? Im running out of ideas!?
bart simpson
Oct 21, 2012 08:02 AM
fujimi
Oct 8, 2012 11:01 AM
nadana
15
Aug 4, 2012 03:57 PM
Tim2179
Feb 20, 2007 12:08 PM
rpv173
Jul 24, 2005 09:15 AM
