Which relay is this?
Old May 17, 2011 | 03:48 PM
wutupnut's Avatar
Default Which relay is this?
Car is a 90 crx.
Noticed a bare wire, traced it down to this relay which was just shoved up in the wiring harness. Needing to know which relay it is and where the wires run to as they need to be replaced. It looks like the two black wires that lead into the pin got hot and melted or were fried?
Edit: Wires run up to the right side of the dash and are wrapped into another harness, ignition switch harness?
Old May 17, 2011 | 04:04 PM
thiendegigolo's Avatar
Default Re: Which relay is this?
the beeping indicator...you kno when you have the key in the ignition and your doors open..and it goes BEEP BEEP BEEP BEEP..thats it right there
Old May 17, 2011 | 04:11 PM
wutupnut's Avatar
If that's the case then it can stay the way it is =p Thank you
Daonlyone74
May 17, 2015 09:33 AM
LowNSlow96ls
Aug 16, 2014 10:03 PM
07civicSI
11
May 11, 2007 08:35 AM
