B-series harness help!
Old May 17, 2011 | 12:42 PM
anzh86's Avatar
Default B-series harness help!
I have 92 eg that came with a d15b vtec. still trying to swap it for a b16, got a b16 alternator so the harness doesn't fit. I was wondering how hard it would be to put vtec into a b18 non-vtec harness? because so far i found a b18 non-vtec harness and a gsr harness, the gsr one is gonna cost me around twice as much as the non-vtec harness.
any help is appreciated, thanks
Old May 17, 2011 | 06:21 PM
anzh86's Avatar
Default Re: B-series harness help!
bump? easy to wire vtec?
Old May 17, 2011 | 06:28 PM
EJ8_Man's Avatar
You can build your own conversion harness
http://ff-squad.com/tech/wiring/obd1-2dizzywiring.jpg
Old May 17, 2011 | 09:52 PM
anzh86's Avatar
Thanks, but i'm still kinda noob with electrical. So obd1 swap, obd1 alternator, obd1 integra harness, should be plug and play right? with the exception of the vtec wires.
Old May 18, 2011 | 05:51 AM
94EG8's Avatar
Seagull Management
Correct. If the civic currently has an EX/Si or VX engine harness yes you can open the loom up and pull out the vtec wiring, depin it at the shock tower plugs and put it into the Integra harness.
Old May 18, 2011 | 06:01 AM
EJ1_CRIS_909's Avatar
You can keep you original harness and just covert ur b16 alternator to work with ur current harness. Itll be alot cheaper and easier. All you do is open the back part of both ur alternator, and the b16 alternator, and switch the plugs.
Old May 18, 2011 | 06:06 AM
94EG8's Avatar
Seagull Management
You can't always switch voltage regulators like that, if they're both Denso alternators yes you can, but if one of them happen's to be a Mitsubishi alternator (most D-series are) you can't.
Old May 18, 2011 | 06:15 AM
Didnt cross my mind at the time of posting that he had a single cam alt. Thanks for the correction of false info in my part
Old May 18, 2011 | 06:46 AM
94EG8's Avatar
Seagull Management
If it's a Denso SOHC alternator you can still do it, actually you can use the voltage regulator out of Denso alternators for completely different vehicles in several cases.
Old May 18, 2011 | 12:54 PM
anzh86's Avatar
my bad everyone, i was tripping. the harness fits the alt, but not the dizzy. Thanks for the dizzy tech link. So i can just use the sohc vtec harness, depin and convert the jumpers for the dizzy and then add the vtec lines and i should be good right?
Old May 18, 2011 | 06:34 PM
anzh86's Avatar
what about a distributor jumper harness? i think it's about $40 and i dont have to tear apart anything
Old May 18, 2011 | 06:48 PM
Thats pretty crazy, i didnt know that. Good info
Old May 18, 2011 | 08:53 PM
NotAJDMFanBoy's Avatar
You can just make a subharness instead of adding the wires into the existing harness. That's what I did on my old 4 door. Ran the wires through the firewall, and just zip tied them to the shock tower brace until I did my swap.
Old May 19, 2011 | 01:28 AM
HondaPartsHero's Avatar
Technical Hero
You'll have to wire up a knock sensor as well. I'm assuming your new engine is OBD2? Otherwise the distributor should plug right in.
Old May 19, 2011 | 08:36 AM
anzh86's Avatar
engine is obd1 from a delsol vtec. i think i'ma just get the dizzy jumper harness because the dizzy i got was obd2; prev owner had it in his ek.
Old May 19, 2011 | 08:50 AM
Jdm_driver4's Avatar
just start cuttin and splicin' the experience is good to have and it really isn't that bad.
1BADEGDC2
Feb 9, 2009 07:25 AM
turboteg90
Jun 10, 2008 12:13 PM
unrivaledintegra
Jun 9, 2007 12:37 PM
nvmyb20hatch
Nov 30, 2005 12:02 AM
CLICC916
Aug 13, 2003 05:43 PM
