Suspension & Brakes Theory, alignment, spring rates....
Brake suggestions for K20a EK..
Old May 17, 2011 | 08:48 AM
Jon777's Avatar
Default Brake suggestions for K20a EK..
I am planning to do a K20a swap and I am looking at brake upgrades. I have stock brakes on my 98 EK HB..4 lug ofc.. I have 15x6.5 +40 offset Rota Slipstreams.. I have read about brake kits not fitting into this setup and I have read of Fastbrakes being recommended quite a bit..but I can't find the thread anymore and I don't know the exact brake model/type..
I'd like to stay 4 lug since I just bought my rims a few days ago..
1. What's the OEM specs for 98 EK HB brakes in terms of rotor size?
2. Suggestions on specific brake brands/models and rotor size and other specs would be appreciated..
Thanks.
Old May 19, 2011 | 05:01 AM
Jon777's Avatar
Default Re: Brake suggestions for K20a EK..
Anybody?
Old May 19, 2011 | 07:52 AM
paul_os's Avatar
is it an ek4 yea? I think willwood do upgraded set ups to suit most fitments and are meant to be very good
Old May 19, 2011 | 08:10 AM
m_shake's Avatar
Do you have rear disc now? Fastbrakes is the best bang for the buck, the cheap kit that uses vw carrado g60 rotors and si/ex calipers.
Old May 19, 2011 | 08:31 AM
FlewByU352's Avatar
I would take it a step further and get ITR brakes. BrakeExpert has a setup with ITR calipers, Prelude VTEC rotors redrilled to 4x100. I just put those on my EK and now I worry more about more tire traction rather than more braking power.
Old May 19, 2011 | 07:12 PM
AtomAutoParts's Avatar
We have cross drilled, zinc plated rotors available, email atomparts@hotmail.com for more info.
Old May 26, 2011 | 01:31 PM
The Hire's Avatar
I have k20r swap as well.
I did ITR front and GSR rear disc brake upgrade in 4x100.
Just order ITR spec rotors for the front and have them re-drilled to 4x100.
Old May 26, 2011 | 02:00 PM
CMOKcuhz's Avatar
i would recommend goin itr and 5lug cus wouldnt the axles connect to tranny? ud kinda be forced to 5lug
thapimpfromchi
21
Jan 10, 2011 01:52 PM
heunde
Jun 12, 2009 02:13 PM
trakwhore
Apr 22, 2008 01:52 PM
Ek527
Dec 6, 2005 02:54 PM
Ashnice
Jun 30, 2004 02:59 PM
