bar question
Old May 16, 2011 | 06:19 PM
an1mositySID's Avatar
Default bar question
can you bar an obd2 gsr with an b16a2 head in a 2000 si in california
Old May 16, 2011 | 07:37 PM
EJ1_CRIS_909's Avatar
Default Re: bar question
I believe it is possible, as long as you can get all the smog components hooked up correctly and you keep it obd2 with a obd2 GSR ecu and if you can pass a emissions check with it. You should be able to pass the visual without a doubt assuming its stock.
hmtcrxsir
May 31, 2009 12:22 AM
Ti3d in
May 8, 2004 07:06 PM
Mr_CRX
Jan 20, 2004 08:42 AM
0gsR
Dec 26, 2001 02:10 PM
