Odd connector on ECU of GSR EK *PIC*
Tied into the harness right at the point where it goes in the ecu. I can move it back and forth and it seems to do nothing with driving.
There's no tech when someone ghetto rigs something like that. My guess is its a VTEC switch using a potentiometer, but you'll have to trace the wiring to confirm.
I obviously didnt do the mod so what does that have to do with you guys not knowing your ****? Its not a vtec switch or change vtec engagement when its moved
Edit:A quick google search reveals that HondaPartsHero is most likely right, you can read up on that here http://en.wikipedia.org/wiki/Potentiometer
Then remove it. It didn't come from Honda and you said yourself it doesn't seem to do squat. Don't know how we are suppose to know what friggin' function that hack job is supposed to preform and how that means we don't know our ****. Apparently neither do you.
As was already said, we did not put that switch in your car, none of our cars have that switch because it is not stock. How the hell are we supposed to know what it does? Follow the wires to wherever they are spliced in to your car and get back to us or ask the person that wired that switch into your car. Stop getting your panties in a bunch because we don't know what some random switch in your car does when we didn't install it. The tech is lacking because you didn't give enough info for us to figure it out since you obviously have no idea how to do it yourself.
Maybe someone put it there simply to confuse you, and make you look like a complete idiot by trying to make all of us look like complete idiots? Anything is possible
Ah the benefits of buying someone else's project/hack job. As far as us not knowing our **** as you so politely put it, there are over 1000 ways to hack a car's wiring and only one way to fix it, correctly!!! Trace it and you need to tell us where it goes, until then the only person who can help you, is you!!!
Hope this answers some questions for you.
"Fool the ecu
We fool the ECU by providing a similar voltage that the FTP would normally send -- this happens to be around 2.5v. You need to acquire a 10k linear potentiometer: Radio Shack Part Number 271-1715.
The outter 2 pins are going to be +5v reference and ground (does not matter which), while the center pin will be your output feeding back to the ECU pinout.
http://www.ff-squad.com/technet/code91.htm
"Fool the ecu
Ok now we have some good info going on here. Anon mentioned bypassing the eld and this car currently throws two codes 1 for a P1298 and the other a P1457.
These are the codes defined...
Electric Load Detector (ELD) Circuit High Voltage
Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System) EVAP
I am not mad at all, just frustrating posting up threads with no answers. Also its kind of obvious it was not stock so thats why I asked the question of hey anyone know wtf this is? Does that sound normal?
I have tried to adjust while driving for vtec or to see if idle changed and nothing happened.
I will get a photo up tonight on the wiring harness on where its actually going to. Will also post up the fix when it happens. The previous owner had these issues with the car so of course everything transferred to me.
I'm pretty sure it's a potentiometer to fool the ECU into thinking the car has a fuel tank pressure sensor (otherwise you have to swap in an EX gas tank and wire in the FTPS)
Take a look at this link and see if it uses the same pinout, you've got an OBD2A setup btw so check under the OBD2A section.
http://technet.ff-squad.com/code91.htm
Ok now I am starting to really get confused... so the car is a 99 dx hatch, the motor a 99 gsr.. You sure its OBD2A? I dont know what harness they used. Let me know how I would post the plug pinouts, if its a picture of the harness going into the ecu with those three cables from the odd connector, let me know thanks!
