NC 1997 TURBO White JDM Front Integra RLZ Built/AEBS Sleeved 11,000 miles !!!MUST SEE!!!
Old May 16, 2011 | 12:05 PM
02type-sk20's Avatar
Default 1997 TURBO White JDM Front Integra RLZ Built/AEBS Sleeved 11,000 miles !!!MUST SEE!!!
Now has a greddy type-s bov
TRADE PLUS CASH ON YOUR END FOR A 05-06 !RSX-S!,
Means of Contact (PM? Email? Phone?): pm,reply, 919-279-3480 CALL OR TEXT ANYTIME
Year - Make - Model - Trim Level 1994 Acura Integra GS-R
Miles: 11,000
Price: $13,000
Title Type: Clear
Activities: Drifting, Off Roading, McDonalds drive thru
Smoked In?: No
Picture Included In Message: Box? (MUST have one picture minimum or thread will be deleted): Yes
The Bad: some paint chips here and there
The Good: fresh build. FRESH REBUILT TRANNY WITH 10MILES AS OF 4-7-2011!!!!!! Its not yours. ALL V-BAND!!!$$$$$$$$$$$$ I can keep my seats to make the car cheaper. Along with axles.
$$$$$$$PRICE DROP 13,000axles$$$$$$$ seats are sold!!!!!
JUST SPENT $400 ON WHEELS AND $500 ON A TRANNY REBUILD AS OF 4-7-2011 If you have a problem with the price then build the car yourself! THANKS:woot:
!ATTENTION!: HOOD IS PROPPED INT HE REAR. IT LINES UP 100%
SPECIAL THANKS TO PAUL DIAZ! www.carshotzonline.com
I really dont want to get rid of this being a 6 month build, but i have other responsibilities on my hands being a college student. This car was eventually going to be magazine worthy. I hope someone can fulfill that and take care of it the way i do.
This car is done right. Nothing to hide here
WILL HAVE MORE PICS THESE ARE THE ONLY ONES ON MY MAC. THE VALVE COVER IS NOW WHITE WITH EAT SLEEP RACE.
NO JOY RIDES PEOPLE.. SERIOUS BUYERS ONLY
No expense spared with this build. NOTHING BUT QUALITY.
INT. 8/10
EXT. 8/10
407HP 294TQ 18PSI. Tuned On Neptune By Howard At RLZ! MOTOR IS BUILT FOR 800+. I PURPOSLY OVERBUILT THE CAR FOR RELIABILITY. HOWARD AT RLZ IS RUNNING THE SAME SLEEVES IN HIS TRACK CAR WITH OVER 800HP
ALL MODS HAVE 6K AND WERE DONE WHILE THE MOTOR WAS BUILT
Aebs t sleeved 2.0L
Wiseco 84mm 18cc dish piston
eagle h-beam rods with arp bolts
arp head studs
type-r crank
Acl main bearings
Acl thrust bearing
Acl rod bearings
new oil pan gasket
moroso oem style pan
Braided return and feet line
New rear main seal
new top end gasket
new type-r oil pump
professional products 68mm throttle body
type-r intake manifold ported to throttle body and head
precision 46mm viand waste gate
hondata 3bar map sensor
precision 600hp intercooler
mishimoto radiator
AEM fuel rail
new distributor cap and rotor
flex a lite fan
red samco hoses
full custom vibrant intercooler piping couplings and clamps
comp stg4 6 puck clutch with pressure plate
new throw out and pilot bearing
comp street light flywheel
Innovative billet mounts
DSS 2.9 axles $$$
walbro 255
new honda timing belt
4" Vibrant filter
Moroso catch can -12 an
SLS Ramhorn manifold t4 vband
sls vband dump tube
sls 3inch vband downpipe
Cometic Head gasket .030
new type-r water pump
precision 780 cc injectors
ngk blues
access hot internal distributor coil
New full oem honda engine seal/gasket kit
vibrant timing belt tensioner
new alternator
new alternator belt
older mods
Aem true time cam gears
hks ssqv bov
turbonetics t70 turbo POLISHED FINISH!!!!!!!$$$$$$$$$$$
ngk bkr7eix gapped to .28
HEAD
Obd1 b16
comp stg 2 turbo cams
CROWER DUAL SPRINGS
CROWER TITANIAM RETAINERS
COMP STAGE 2 TURBO CAMS
SUPERTECH VALVES W/ 3ANGLE JOB
PORT AND POLISHED HEAD
RJ'S 3inch mandrel bend exhaust no cat/no res to a 3-4inch magnaflow ss muffler
interior
memory fab s68 carbon fiber seats
mint usdm-r rears
apex aver boost controller with solenoid
aem wideband
eclipse 2din navigation/dvd indash
type-r cluster
suspension
k-sport coilovers
omnipower lowercontrol arms
4-7-2011 !!CAR NOW HAS ROTA CIRCUIT 8'S AND IS LOWERED ONCE AGAIN!!!
Old May 16, 2011 | 04:49 PM
Default Re: 1997 TURBO White JDM Front Integra RLZ Built/AEBS Sleeved 11,000 miles !!!MUST SE
upp
Old May 16, 2011 | 08:55 PM
srt4mike's Avatar
Bump for viewing.
Old May 17, 2011 | 08:12 AM
upp
Old May 17, 2011 | 11:08 AM
RookieCivic's Avatar
A true bump!
Old May 17, 2011 | 01:36 PM
egboss's Avatar
clean *** teggy bro
Old May 18, 2011 | 04:23 PM
bump thanks guys
Old May 19, 2011 | 05:05 AM
hatchboiracer's Avatar
has anything changed? what parts have you sold already? im kinda intrested, i have another deal going on but not sure if its gonna go thru.
Old May 19, 2011 | 07:00 AM
Seats are sold, Put in an MSD Blaster ss External Coil and a Greddy type-s BOV.
WallysDa
Mid-Atlantic (Sales)
Jan 21, 2014 04:57 AM
RiceBurnerRebel
May 5, 2011 12:16 PM
02type-sk20
Apr 21, 2011 04:47 PM
OneBadDC2
Aug 9, 2010 08:04 PM
JustMike
Northern California (Sales)
19
Mar 5, 2008 09:17 PM
