Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
99 3.2 TL cruise control problem???
Old May 16, 2011 | 10:38 AM
dungeonKing's Avatar
Default 99 3.2 TL cruise control problem???
While driving with the cruise control on @ roughly 80 m.p.h., it turned off and the traction control, air bag, and abs lights flashed. All the gauges went down momentarily and then returned to their previous position.
Besides that, nothing out of the usual occurred. I was able to pick my speed back up and re-engage cruise control. Since then, no problems.
I was just wondering if this has happened to anyone else. Any input would be appreciated.
Thanks in advance.
Old May 17, 2011 | 06:13 AM
1GPlusSH's Avatar
Default Re: 99 3.2 TL cruise control problem???
Check your ground on the battery. Make sure the cable is secured and not corroded.
Old Jun 16, 2011 | 05:18 PM
dmarshall23's Avatar
sounds like an ignition switch problem. there is a recall on these. even if its beeen replaced before acura sometimes let them be covered under warranty again
Old Jun 23, 2011 | 05:50 PM
justinsbg's Avatar
Defnitiely sounds like an ignition switch problem. But, just to be on the safe side it's always good to check your battery posts for corrosion A.K.A "Green Death", and tightness.
The Cars
Dec 29, 2011 10:13 AM
baybeboi
May 9, 2003 05:50 AM
