Cruise Control Problem
Old 05-08-2003, 10:34 PM
baybeboi's Avatar
Default Cruise Control Problem
My Cruise Control on my 99' civic doesn't work, rarely it would work but now it just stopped working at all. What should i do? How can i fix it?
Old 05-08-2003, 10:51 PM
4DeepCivic's Avatar
Default Re: Cruise Control Problem (baybeboi)
Have you tickered with your clutch pedal? There is a switch on the pedal that can turn the C/C off. Check the C/C switch. Good Luck
Old 05-08-2003, 11:04 PM
b19coupe's Avatar
Also check your brake switch, one of the most common causes of cruise control problems.
Old 05-09-2003, 12:23 AM
racecarpete's Avatar
Default Re: Cruise Control Problem (b19coupe)
check the vacuum lines under the hood.
Old 05-09-2003, 05:50 AM
VRD^don's Avatar
i had the same problem.....
tangopampa
04-24-2015 07:45 PM
Juan_Mitosis
06-19-2008 11:13 PM
gen4acclude
02-15-2005 07:07 PM
Kevedge
08-19-2004 01:40 AM
kjou2001
06-03-2004 03:24 PM
Quick Reply: Cruise Control Problem
