Skunk 2 Coilovers? Thoughts?
Old May 16, 2011 | 05:50 AM
JPerkMr954's Avatar
Default Skunk 2 Coilovers? Thoughts?
I'm considering getting a set of Skunk 2 coilovers for a 00 civic coupe, just looking for some feedback from people who might have used them in a same setup...
I also need new shocks, I feel mine are dead, so thats also another issue.. But I'm just trying to see what people think about them as I have some other suspension setup options...
Old May 16, 2011 | 06:05 AM
BlackCivicEX's Avatar
Default Re: Skunk 2 Coilovers? Thoughts?
Are you looking at coilovers? or coil sleeves?
i have them in my 93 hatch.
The skunk2 s2 coilovers with my road conditions, i with i would of chose a higher spring rate, because i feel all bumps badly. Handle corners smooth at high speeds, overall seem decent, but always better for the $.
budget wise? progress series or the koni/groundcontrol combo. best bang for your buck.
Old May 16, 2011 | 06:28 AM
Libertariat's Avatar
Ek Forever y0!
The best bang for the buck are Koni/Ground control at $800.
The next down is progress CS-II (which I have) at $580.
You can't go wrong with either of those. If you can't afford the Progress CS-II you should wait and save up for them. There's a wonderful vendor thread in the marketplace with tons of feedback from daily drivers, auto crossers, and HPDE folk praising progress.
Progress and Koni have been in the business for a long time. The only skunk2 product I'd buy willingly is their valvetrain. Even then I'd rather have a custom grind done.
Old May 16, 2011 | 01:29 PM
baca00ex's Avatar
I currently have the Skunk2 Pro S Full Coilovers v2 and have really enjoyed them, when I'm driving on good roads. Unfortunately for me, I live in central south texas and ALOT of gravel/uneven and simply bad roads around here. So they are rough as heck and you can feel almost every bump, basically make sure you goto the bathroom before taking a long trip.
Handling is amazing on them, however I've also added the lower control arms, rear lower tie bar, front/rear strut tower bars and front/rear cambers (all from skunk2). Running with Yokohama S.drive 205/45R-16, have them adjusted/lowered to where they are nicely tucked into the fenders. You have to be really careful though, before I had them adjusted correctly they would rub/wear out the inside fender wall.. leaving a hole in it. So had to replace that once I got them adjusted correctly, now I can fully turn while on rough road conditions and I'll get no rubs.
Overall though, I really like them and probably will stick with them. The only other option would be to go with Pro C, personally I'm not a track/rally racer.. so didn't really see the point in goign the next step up, the Pro S work just fine and cost around 700$
Old May 16, 2011 | 02:49 PM
Ek Forever y0!
Pro S are that much?
For another $100 you could get koni/ground control and you'd get a lifetime warranty on the shocks.
I don't know why when there are lifetime warranties to be had people are so quick to get something different.
Old May 16, 2011 | 02:53 PM
98civdx's Avatar
Master Detailer
I have skunk2 slips on's. For what they are, and how much I paid for them, they are fine.
batallic's Avatar
i got Skunk2 coils on koni yellows, its a bit harsh but bearable mind you this is the shocks on full soft
Old May 16, 2011 | 03:15 PM
JPerkMr954's Avatar
I meant sleeves... not full coils!! If im going to go full coils it would probably be the GC/Koni setup... But I also have heard that "Megan" has a good set for a good price...
Old May 16, 2011 | 03:22 PM
Ek Forever y0!
No they don't. Progress CS-II is the best thing under $800.
Good warranty, phenomenal customer service.
I've spoken on the phone with their reps for 20-45min intervals. Almost everyone working their has been racing for years.
You can pick your rates, with megan you can't.
Replacement parts for CS-II's beyond the warranty are cheap. ~$65 for a new shock, $90 for a set of springs. So even if you'd like to have 350/250 for winter/daily driving and 350/500 for autocross season you can do that. Just swap the springs.
Old May 17, 2011 | 10:56 AM
JPerkMr954's Avatar
Interesting...Might have to look into this more...
you_ignant
Suspension & Brakes
24
Jun 20, 2011 03:30 PM
noobhonda23
24
Mar 31, 2010 04:31 PM
FRKWOO
30
Nov 7, 2009 04:34 PM
SiR Inspired ED7
11
Aug 27, 2006 10:06 PM
mooseknuckle
Jul 13, 2004 10:49 PM
