GSR throwing Electric Load Detector (ELD) Circuit High Voltage and Lag Under Low RPMS
Old May 15, 2011 | 10:48 PM
MoreCowbell's Avatar
Default GSR throwing Electric Load Detector (ELD) Circuit High Voltage and Lag Under Low RPMS
So I have a code
Electric Load Detector (ELD) Circuit High Voltage and my gsr seems to be running sluggish all the way up to 3k rpm and then it just seems to get the power right back and act normal. The car sometimes acts fine for a while till its driven for 30 minutes or more then it will have the problem. Also seems to be hotter than normal under the engine bay.
Just stating the issues.. Any ideas? Thanks!
Old May 15, 2011 | 11:50 PM
el crapitan's Avatar
Default Re: GSR throwing Electric Load Detector (ELD) Circuit High Voltage and Lag Under Low
check your charging voltage.
if it's fine, 14.3-14.5v, try clearing the code. see if it comes back.
the eld is located under the under hood fuse panel, if you do end up needing to replace it. sorry, but i don't know the testing procedure for it
Old May 16, 2011 | 12:23 AM
Will do.. Any other suggestions for when I go to work on the car tomorrow?
Old May 16, 2011 | 03:55 PM
Have not checked but here is pic of the fuse panel
Old May 16, 2011 | 07:24 PM
i believe you have to unbolt the panel. it should be located underneath
Old May 20, 2011 | 09:43 PM
bump for more suggestions
Old Jun 4, 2011 | 12:12 AM
up
Old Jun 4, 2011 | 07:15 AM
fcm's Avatar
fcm
Old Fart
Did you check charging voltage?
It sounds like the voltage regulator is on it's way out. 94
Old Jun 5, 2011 | 07:19 AM
follie gatts's Avatar
Are you popping any fuses?
Make sure your negative battery terminal has a good ground to the body. Check for continuity between the battery and where that wire bolts to the body six inches away.
Old Jun 5, 2011 | 07:17 PM
PROJECT_DC2R's Avatar
I recently had this problem on my 98 Integra GSR with the CHV and lag under low rpm as well. The problem that was causing it was the o2 sensor went bad. Not sure if that's any help, but check it out. Never know.
Old Jun 10, 2011 | 08:45 PM
I turned off the eld in Neptune and it's running fine now. Temp solution to this issue I guess. I see the battery voltage being14. Something while driving
Old Jun 11, 2011 | 12:20 AM
Wish I knew about the crv eld... What's funny is I just got a 00 crv and it has the same eld as my 99 dx civic
b18c-gsr
Jan 30, 2025 04:40 AM
CRX Hooptie
17
Feb 19, 2011 12:14 AM
mhewitt
Sep 16, 2010 10:03 AM
Rusted
Honda Civic (2001 - 2005)
Sep 8, 2006 08:48 AM
jiggy
Sep 12, 2005 08:18 PM
