Integra OEM dual bend shifter in 99 Civic Si without cutting or bending??
I'd like to try a dual bend Integra shifter in my Civic Si, but I found out that the base is wider. I see that some people cut it and others spread the linkage out to accommodate the wider base. What linkage parts would I need to buy to make it fit properly without doing the above? I seem to recall someone mentioning this was possible, but I haven't been able to find any details. Any help would be appreciated!
Attached picture doesn't belong to me, but shows where people normally cut.
I thought all B series shift linkages would accommodate an integra shifter, that picture above is for an Integra shifter w/ a D series shift linkage AFAIK. So if it doesn't fit then I guess you'd need the integra one?
i would not recommand stretching the linkage. I did this diy a while back on my 99 si. I simply grinded off a bit so that the bearing would fit perfectly. I dont see any other way of doing this diy other than switch to a type r shift linkage etc. but trust me, its worth while doing this. feels much better and precise in shifting and it doesnt break your wallet. If can, install the energy suspension shifter bushing at the same time
if that came off an integra then yes.....i cant tell by the picture.... someone correct me if im wrong.. but im pretty sure integra linkage+shifter fits in any car with a b series....again correct me if im wrong, its been a while
i currently have a 99dx with a b16a2 swap... running full integra linkage and shifter from my old integra LS...
ive never used an ITR linkage before so i dont know if its thicker..... i always thought all integra ones were the same besides the ITR one being corrosion resistant.... but imo a regular integra should do... ITR ones go for like 60-100 bucks ... regular integra ones i sometimes get for free lol
U guys are too oem. Go with a twm single bend short shifter. Dual bends position the **** farther away from the driver.
Cool Cool Island Breezes. BOY-EE
You need an integra linkage. They're all the same. Don't be fooled into paying more for an ITR model. The only part of the linkage that will fit an EM1 is the actual shifter part. The one with the bitch pin in it. The stabilizer WILL NOT clear the secondary O2 sensor on a 96-00 civic.
I've been thru this on my EM1. I currently have an integra shifter and a gold ITR linkage that came with my ITR swap. Again, all the integra linkages are the same. I believe the shifters are all the same also. Certain year (00-01 USDM) ITR shifters are chrome and the JDM linkages are gold. Color is the only difference.
All 88-00 civics come with the same shifter. Meaning that linkage itself is narrower at that part.
The 94-01 integras all come with the wider shifter base. So the linkage is wider at the corresponding area. The linkage itself is also a larger diameter and I believe has tighter bushings/joints.
Short throws don't feel as good as the OEM integra shifter/linkage. The linkage is beefier so it feels nicer. The shifter is the PERFECT amount of shortness. I used to have a skunk2 on my EM1. It didn't feel anywhere near as nice as the stock Integra parts do now.
I just don't like the feel of short shifters. I also had a Skunk2 and removed it shortly after the install. It's a solid steel shifter, but OEM with ES bushings was better for me. Although it was a dual bend, I don't know if the **** distance is any different from an OEM Integra's. Everything I've read states that dual bend allows the **** to sit closer to the driver.
Use the civic stabilizer. Use the integra...other...bar...thingy.
yes. You're only using the integra gear selector linkage. You use the EM1 stabilizer bar.
I got a question. Sorry for reviving old thread but is there any difference between the Si stabilizer bar and Integra? The reason I'm asking this is when I put in my B swap, I used the whole shifter linkage and shifter from a GSR and sitting in the driver seat with no shift boot just noticed that the shifter looks a bit forward? I mean in neutral the shifter looks like it's in third.
Or you could just take the shifter to a muffler shop and have them trim 2mm off one side and 7 mm of the other.
