... apexi vafc and diy wideband
Old Sep 30, 2002 | 06:42 AM
1.8T_EG's Avatar
Default ... apexi vafc and diy wideband
... it is possible to send the output from the diy wideband (techedge) kit to display on the vafc?... lemme know... thanks...
Old Sep 30, 2002 | 09:14 AM
Hal's Avatar
Hal
Default Re: ... apexi vafc and diy wideband (1.8T_EG)
Yes it is, but it's not going to be real helpful.
There is a "blue wire" on the afc harness, which is often unused.
You can connect this to pin 7 on the DIY male DB 9 connector, and then connect
pin 6 to the AFC ground.
This will let you see the w/b voltage while the AFC display is in "sensor check"
mode.
A better solution is to use a Palm or Laptop and log the wideband output directly
from the display using the freeware loggers.
Hal
[Modified by Hal, 6:14 PM 9/30/2002]
Old Sep 30, 2002 | 09:50 AM
1.8T_EG's Avatar
Default Re: ... apexi vafc and diy wideband (Hal)
... hehehe... Hal, this is AJ from the Springs... i stopped by your place this weekend and talked to you about the techedge kit... thanks again... and good luck with the car this wednesday up at bandimere... ttyl...
[Modified by 1.8T_EG, 12:42 PM 9/30/2002]
Old Sep 30, 2002 | 10:02 AM
civictypenos's Avatar
so it would just measure voltage?then you would have to use the graph to match up what the ratio would be???
b18cEK
Jan 5, 2016 08:22 AM
darkstarsi
Oct 27, 2003 05:39 PM
dnt94civic
Aug 22, 2002 01:52 PM
uncleben
Jul 3, 2002 04:49 PM
