installing b20b from the bottom? What mounts go on before? which after?
Old Sep 30, 2002 | 06:41 AM
Will Albers's Avatar
Default installing b20b from the bottom? What mounts go on before? which after?
If im pulling the engine up, do i want any mounts attached onto the engine? or do i put them on after the engine is in position?
Old Sep 30, 2002 | 06:43 AM
SuperCivic's Avatar
Default Re: installing b20b from the bottom? What mounts go on before? which after? (Will Albers)
maybe the tranny side mount..but you'll have to wait to install the rear and the driver's side. also be aware on b20 that you need to change the driver side mount bracket to a b16/b18a mount bracket.
Old Sep 30, 2002 | 07:22 AM
Magick211's Avatar
Default Re: installing b20b from the bottom? What mounts go on before? which after? (SuperCivic)
Alot of mount kits require that the rear tranny mount be aligned first.
Old Sep 30, 2002 | 08:03 AM
dohcsideSi's Avatar
Default Re: installing b20b from the bottom? What mounts go on before? which after? (CivicBoyZC)
going from the bottom leave all the mounts attached. on the rear mount/tranny mount only put the top bolt in so you can swivel it up and down to clear the rear x-member. trying to put that bracket in after the motor is a pain in the a$$
hatchyksp
21
Mar 3, 2009 03:04 PM
wondersparrow
Apr 28, 2008 12:03 PM
Del Sol on Steroids
Apr 13, 2007 04:23 PM
97civicdx
Feb 9, 2005 12:32 PM
EJCivJdM93
Feb 9, 2005 04:40 AM
