Stoker 240HP NA B20v EK 96' CHEAP Job lost sale!
Old May 15, 2011 | 02:25 PM
Chee_dog's Avatar
Default Stoker 240HP NA B20v EK 96' CHEAP Job lost sale!
YEAR:1996
MAKE:Honda
MODEL:Civic
MILES:19x,xxx
DESCRIPTION:read below
PRICE: 4500 OBO
This is currently my daily driver and toy but I just recently lost my job so I the extra cash would help pay some bills.
Car is on E85
b20 block
golden eagle stroker crank
eagle rods
84mm cp stroker pistons 11.5:1
cometic head gasket
golden eagle lsvtec line kit and sandwich plate
gsr head pnp (Dan Paremore Racing)
skunk2 intake mani pnp (Dan Paremore Racing)
skunk2 70mm throttle body
skunk 2 stage 2 cams
skunk2 dual valve springs and retainers
aem cam gears
750 rc injectors
aem fuel rail
hondata intake mani gasket
Gsr transmission (no grinds)
endyne breather kit
autozone axles lifetime warrenty
Hytech Replica Header
Act 6 pluck with lighten flywheel (less than 7K)
JDM blue valve cover
JDM ITR crank pulley
Innovative Mounts
short throw shifter
255 fp
Two-three years ago it made over 240 at MAP perfomance here in MN. It is currently sitting on the old base map since the ecu was stolen but I suggest a retune anyways.
Currently on Fat fives and steelies
99-00 conversion
hid retrofit
Tien flex coilovers
ctr replica wing
Issues need to be address
-I suggest getting a retune but if not, it is fine and can still haul *** just running rich.
-Front bumper has rock chips and needs and a crack so could use replacement.
-loose window handle because i lost the clip
-needs alignment
-slight idle surge when it warms up
-two header studs are strip
-small paint chip on the quarter panel due to lca broke off and wheel scrape.
-Brakes need to be rebleed.
These are just comestic things that would make the car 100% and I'm a picky person so some of these don't even need to be address.
Will get update picture SOON BUT THESE ARE OLD PICS. DOn't HAVE THE GRIDS ANYMORE.
Old May 16, 2011 | 05:07 PM
georgethao's Avatar
Default Re: Stoker 240HP NA B20v EK 96' CHEAP Job lost sale!
Are you up for any trades?
Old May 16, 2011 | 09:26 PM
Chee_dog's Avatar
I will trade for a 4x4 truck if not I perfer cash so i can pay some bills.
Old May 17, 2011 | 12:14 AM
got00rice's Avatar
u from MN if so pm me a number, im interested in this. thanks
Old May 17, 2011 | 06:42 PM
RyanA's Avatar
Tuner or Pro cams?
Old May 17, 2011 | 09:46 PM
Chee_dog's Avatar
pro series
Old May 20, 2011 | 10:36 AM
Chee_dog's Avatar
Old May 20, 2011 | 01:30 PM
ProudToBeAwesome's Avatar
i want this but i highly doubt it would pass emissions =[
Old May 20, 2011 | 05:57 PM
Chee_dog's Avatar
wi does emission test?
Old May 22, 2011 | 08:35 AM
sadly i live in the cluster that does =[
Old May 22, 2011 | 07:23 PM
bukkowben's Avatar
Pretty good deal! Bump for you!
Chee_dog
May 25, 2011 10:48 PM
Bigplans06
26
Apr 12, 2010 08:07 PM
egCoupe
Aug 15, 2005 05:55 PM
redcivicek
Sep 29, 2003 02:37 PM
