Would a blown fuse make turn signals flash quicker?
Yesterday I went to auto zone to have one of the workers there check out my left side blinkers due to them blinking fast. He check em out and said my bumper turn signal was bad, so this morning I removed it and it looked ok but I went back anyway to see if in fact I really needed a new bulb. The guy pulled out his meter checked the bulb and told me it was but told me the problem could possibly be the fuse. So I was wondering if in fact a blown fuse could be the reason why my left blinkers are flashing so quick and which fuse is it or is the problem bigger than that?
My turn signal works and all the bulbs flash, its just that when they flash they flash quicker than usual as if one of the bulbs were blown but thats not the case.
On the '94 there is a park/indicator lamp in the bumper and the corner/fender lens. These both flash when signalling. With a single lamp in the tail light.
Are you sure all your signaling lamps are working?
Im not sure if the bulbs that are installed on this car are the correct wattage, but all lights go flash when signaling. Do you know what wattage the bulbs should be? I may just make a trip and get all new bulbs and see if that fixes the problem.
EDIT: also verify that the flasher is correct.
