ECU Question!
Old May 15, 2011 | 09:30 AM
B18_badboy's Avatar
Default ECU Question!
Hey guys. Ive got a 92 hatch with a b18b1. So I was wanting to know if the P28-A02 ECU in there right now is the right one!? Thanks guy..
Old May 15, 2011 | 09:49 AM
Got_boost_97's Avatar
Default Re: ECU Question!
im running the P28-A51 with hondata s300 in my 93 hatch with a boosted B16A, but had the A02 and it worked fine
Old May 15, 2011 | 12:11 PM
24TEN's Avatar
PHANTOM MENACE
That didn't actually answer his/her question. P28 is for SOHC VTEC but it can be used on different motors with or without modification but may trigger a check engine light. The correct ECU depends on your engine's specific year and/or OBD configuration but should be P74/P75. In addition an OBD1 PR4 should work just the same if the wiring is setup for OBD1. If you need more clarification check the FAQ or use your favorite search engine.
nathanie1
Oct 21, 2005 01:04 PM
Layziebtnh055
Apr 6, 2004 08:22 AM
volkracing99
Jan 17, 2002 01:06 PM
