MI S2000 AP2 Motor everything new 11K Shaved tucked Custom
Old May 15, 2011 | 09:17 AM
MainStreamHonda's Avatar
Icon3 S2000 AP2 Motor everything new 11K Shaved tucked Custom
Email: Nsinfamy@hotmail.com
Phone: 1-231-830-5653 - Call/Text, does not matter
Payment: Cash, Paypal, Certified check, Money order
Make: Honda
Model S2000
Year: 2000
Check my vin: PM me for it
Price $11000.00 - FIRM
I bought this car Wednesday March 31st 2010 from Arlington Illinois - at 8:58 P.M for $9600.00 I have had this car for over a year now. It has been a great car, no issues minus the ones I did, or upgrades. Right now I am looking to sell so i can get a Lexus Is 300. I do not care what anyone has to say about what I want, all that matters is me.
I am going to list my records that I have kept for this car. Trust me everything is on here pretty much. I have dates and the cost of each part.
Oil Changed at 89,400 Castrol Syn Edge 10W-30 /w OEM HOnda Oil filter - 30.00 - April 5th 2010
New Honda Silverstone license plate caps for the front bumper - 11.00 April 7th 2010
Brought the Car in Betten Honda for a recall, Items replaced April 19, 2010
- Replaced Both SRS sensors in sea belt re-tractors
- Replaced both Tail light housings
- Replaced (4) spark plugs
- New procedsure fro spark plugs: New Torque specs and product number:
- NGKFR7G-11S DENSO: PK22PR-L11S - 18 Ft-lbs
Carbon Fiber radiator cooling plate added - 60.00 - April 7th 2010
New valve cover gasket set From Honda replaced, also painted the valve cover, 32.00 - April 22, 2010
New Full body Blackworks adjustable coilovers installed - 650.00 - July 2nd 2010
New Honda OEM 2009 Club Racer (CR) Shift **** and adjustment nut - 67.00 - July 2nd - 2010
Car was undercoated - 30.00 - July 3rd - 2010
New Honda OEM 2005 Floor mats - 70.00 - July 15th, 2010
Brand new OEM 2004 Rear bumper - 280.00 - July 23rd, 2010
New Battery replaced July 23rd - 90.00 - July 23rd, 2010
Oil Changed at 92,400 Castrol Syn Edge 10W-30 /w new OEM Honda Oil filter- 30.00 - July 23rd, 2010
Car went into Autobody Clinic to have the Brand new OEM rear 2004 Honda S2000 bumper installed and painted. Also the rear quarter panels are going in to have a custom wide body look. 1500.00 - July 26th, 2010
Intake side retainers and keepers were replaced with brand new OEM 2004 S2000 ones. The early -00-03 retainers can crack and break, and the new versions have not failed yet. 75.00 - August 20th, 2010
Stock AP2 V1 rims were sand blasted, etched primed, expoxy primed, painted custom candy metallic blue, and cleared. 297.00 - August 23rd, 2010
Added Two Toyo proxies to the rear 245/40/17. 232.00 - September 9th, 2010
Added two Yokohama Parada Spec 2 to the front 215/40/17 - 240.00 - September 9th, 2010 - Both tires were repalced at 96,400 miles
Car returned from Autobody clinic on September 10th, 2010
15mm Spacers for the rear 70.00 September 10th, 2011
New OEM Honda Oil pan removed oil pan for inspection and forgot one bolt and the pan cracked (my error) - 230.00 September 10th 2010
New Clutch disc (Exedy), OEM pressure plate from Honda, New Honda OEM throw out bearing, resurfaced flywheel, and New Honda Pilot Bearing, 310.00 - September 15th, 2010
New OEM exhaust manifold gasket sicne the old one came off when doing my clutch - 10.00 - September 15th, 2010
NEW SPC Rear adjustable Ball joints, Camber kit - 175.00 - September 15th, 2010
New MOOG front swap bar end links - 45.00 - September 15th, 2010
Oil Changed at 95,300 Castrol Syn Edge 10W-30 /w OEM Honda oil filter - 30.00 - September 16th, 2010
New Honda OEM '03 Civic si Knock sensor - 42.00 - September 24th, 2010
New serpentine belt- 23.00 - September 25th 2010
4-wheel Alignment done at Betten Honda - 70.00 - September 26th, 2010
Oil Changed at 95,300 Castrol Syn Edge 10W-30 /w OEM Honda oil filter - 30.00 - November 16th, 2010
New Timing chain Tensior from Honda - 144.00 - November 16th, 2010
-------------------------------------- Year 2011---------------------------------
New Used Lower front driver side control arm, 48K miles - 70.00 February 9th 2011
Battery terminals - 10.00 - February 9th 2011
2 gauge wire, 7ft - for battery relocation - 20.00 - February 11th, 2011
Paint for cross members and calipers - 80.00 - February 12th, 2011
Engine bay shaved and tucked, and painted- 490.00 March 1st, 2011
New toe arm bolt, cam adjustment, and nut from Honda - 31.00 - March 3rd, 2011
Bought a Honda S2000 F22C Motor From Weaverparts.com with 31,000 miles and a 6 month warranty. VIN: JHMAP2145S002708 - $2393.56 - March 10th, 2011
New Exedy disc - 100.00 - March 19th, 2011
Full AP2 cat back exhaust with tips 50K miles - 150.00 - March 19th 2011
AP2 Cat 50K miles - 80.00- Mach 19th, 2011
AP2 ECU 50K miles - 70.00 - March 19th, 2011
Mishmoto fan switch for radiator - 25.00 - March 19th, 2011
OBX Radiator hoses - 32.00 - March 21st, 2011
Low mileage engine mounts 32K out of a '05 S2000 - 93.00 - March 26th, 2011
Mobil 1 full SYN 75W-90 Gear oil 3 qtz - 23.00 - March 26th, 2011
2 quarts of full syn valvoline brake fluid - 9.00 - March 26th, 2011
Valve cover acid dipped and ready for paint - 45.00 - March 29th, 2011
New inner fender liners for Honda - 138.00 - March 29th, 2011
New OEM Honda Club Racer Serpentine blet without A/C - 38.00 - April 3rd, 2011
New used Rear differential with 96,000 AP1 - 350.00 - April 3rd, 2011
New Headlights - 450.00 - April 3rd, 2011
Engine bay innovations fender bolt kit - 10.00 - April 3rd, 2011
New pads and slotted drilled rotors - 152.00 - April 4th 2011
New Camshaft sensor - 28.00 - April 4th, 2011
Axle bolt and nut - 5.00 - April 4th, 2011
Transmission fluid change with 101,693 with Mobil 1 Full syn - 18.00 - April 4th 2011
Full brake flush and refill - April 4th, 2011
Got 1 drive shaft bolt, two exhaust cat bolts and springs, 20 inner fender clips, steering shaft toothed lock washer - 83.00 - April 5th, 2011
Oil changed with valvoline 10W30 for the first 700 miles and a K&N oil filter - 25.00 - April 4th, 2011
4-Wheel Alignment from Betten Honda - 70.00 - April 13th, 2011
2 Gallons of OEM Honda coolant - 32.00 - April 13th 2011
Honda Programmed my Key to my AP2 ECU - 40.00 - April 13th, 2011
Bought a new Oil pan drain bolt - 8.00 - April 13th, 2011
Oil changed at 102,385 with Castrol full SYN edge ( revamped oil ) 5W-30 - 30.00 - April 18th, 2011
HAMP oil filter added - 18.00 - April 18th, 2011
2 used 30K miles rear axles out of a '03 S2000 - 168.00 - May 1st 2011
5mm spacers for the front - 12.00 - May 9th, 2011
This car has been taken care of as you can see. The really nice thing is all these parts added have little to no miles on them.
The GOOD:
Newer AP2 motor 34K miles now ( still has warranty )
New Brakes
New Brake fluid
New headlights
New inner fenders
New taillights
Engine bay shaved tucked
New Honda OEM coolant
Those are the highlights, for everything new you can look at the list. I also used anti seize on all suspension adjustment bolts and nuts. the car right now drives and runs. It is my daily driver and I love it to death.
Not so great, but isn't going to do damage.
The Top is not in great shape, it will need a new one if you care about it, i use it right now with no issues
The rear 1/4 panel has a chip, I fell off the ladder and took a spec out of it.
Check engine light is no because I removed the air pump
Front lip is cracked but I have a new one for it that comes with the car
I am asking 11K for this car, I paid 9600.00 for it and invested a good amount of quality parts, not just simple stickers to the car. The tires still have 80% left on them, the rims are great, the car stops on a dime, and just is amazing. I get people talking to me all the time about the car and it truly is awesome. Just right now I am looking for something different.
Cool fun fact, this car was the 212 off the line, the vins shows the year and the # it was, it was built in the 6th month of '99.
Also people love the Ap2 Motor with Ap1 transmission, most say this is the best combo for track, or even daily use.
I am in no rush to sell the car, so please don't offer me 10K
Old May 15, 2011 | 09:46 AM
jdcdc5's Avatar
Default Re: S2000 AP2 Motor everything new 11K Shaved tucked Custom
open for trades?
Old May 15, 2011 | 09:57 AM
Right now if it is a lexus I would, but if it is the car in your avatar, I cant :[
Old May 15, 2011 | 09:59 AM
brent_G's Avatar
bump for muskegon. i used to live in twin lake. wish i could snag it from ya
Old May 15, 2011 | 11:00 AM
Thanks man! I wouldn't mind a EVO trade price is 13.5K, but cash is 11K.
Old May 15, 2011 | 12:23 PM
Chunk0286's Avatar
damn clean dude
Old May 15, 2011 | 12:35 PM
Originally Posted by Chunk0286
damn clean dude
Thanks. I will consider other cars I hope for a 4-door though.
Old May 15, 2011 | 02:19 PM
srt4mike's Avatar
Bump for viewing.
Old May 16, 2011 | 06:33 AM
Originally Posted by srt4mike
Bump for viewing.
:] thank you!
Old May 16, 2011 | 05:27 PM
Bump for clean
Old May 17, 2011 | 05:57 AM
go!!!
Old May 17, 2011 | 07:18 AM
vinmotors's Avatar
sent pm.
Old May 17, 2011 | 08:34 PM
Got PM, thanks - still here a lot of offers but nothing yet.
Old May 19, 2011 | 06:28 AM
Old May 21, 2011 | 10:16 PM
SOLD!!!!!!!!!!!!!!!
Reflash
Dec 8, 2008 09:04 PM
SubTitle
May 29, 2008 11:25 AM
mrivera
Southwest
Jan 16, 2008 07:52 PM
Boost Addict
Jan 25, 2006 04:27 PM
Boost Addict
Northwest (Sales)
Dec 8, 2005 01:40 PM
