Excessive Heat from Timing and AFR Settings
Old Sep 30, 2002 | 06:01 AM
EF8_SiR's Avatar
Default Excessive Heat from Timing and AFR Settings
Does adjusting ur timing and/or air fuel ratio to run lean or rich cause the engine to run hotter? And what settings (advance vs retard and lean vs rich) would cause it to run hotter?
Old Sep 30, 2002 | 06:53 AM
HF2ZC's Avatar
Default Re: Excessive Heat from Timing and AFR Settings (EF8_SiR)
Leaning out your air / fuel ratio makes your engine run hotter, as will advancing your timing.
Mantis88ls
May 14, 2004 05:37 AM
SuicideSlide
20
Jan 5, 2004 07:36 AM
tc
Sep 22, 2003 06:10 AM
tc
Sep 21, 2003 06:42 PM
turbotec
Mar 1, 2002 07:03 AM
