Koni Adjustable coilovers info
just looking for some onfo/opinions on these, iv noticed the koni shocks are very popular in the US but i cant get much info on them here in Ireland. Iv been offerd a set of koni fully adjustable coilovers new for a very good price but want to know what there like, how low can they be dropped etc. Iv been told by people here in Ireland that they are a good budget coilover but no one has first hand experience to back it up.
thanks,
Paul
thanks,
Paul
Koni doesn't make coilovers so chances are you have Koni shocks and some aftermarket coilover sleeves.
Also, you really should search.
https://honda-tech.com/forums/suspension-brakes-54/koni-full-coilovers-2893530/
If you searched you would see that Koni DOES make coilover setups.
https://honda-tech.com/forums/showthread.php?t=2893530
Yeah I think it's not really used all that much, considering they're one of the only adjustable-height setups with progressive-wound springs. Most stuff you'll find on the net is people asking for info, but not that much info out there about them.
And unfortunately Koni North America's site isn't working right now.
I did search, and found the thread above, but there was not much info in that thread and i want to hear from someone who has used them before if at all possible
Im still a bit confused here, iv been offered Koni Shocks front and rear,sport and top adjustable. Adjustable 3 diff levels for ride height.
here's the part numbers
Front: 8041 1152sport
Rear: 8041 1213sport
I did a search but cant find what the 3 different height levels are? and also cant find any reviews on them can anyone help me out at all?
so you just getting the shocks? or is it a full coilover?
the 3 different adjustable height might be the perch height. take a pic if you can.
Im not sure they sound like just shocks not coilovers now, and yea my guess is the perch can be set on 3 levels, which determines the height and i presume they are also rebound/bump adjustable.
this is the pic i find when i search those part numbers:
never heard of either? I was just offerd these koni ones at a good price but no one ireland seems to use them so needed some info. Ill probably just save for a good set of HKS coilovers or something but if could pick these up in the mean time if i new how low they would go
the fronts should only have one lowering setting, and the rear should have two.
you would have to get lowering springs or coilover sleeve if you want to go lower. and they are bound adjustable only. but they are good for the money.
edger8cer
Suspension & Brakes
Nov 6, 2005 11:50 AM
80411213sport, adjustable, coilover, coilovers, fully, good, height, honda, info, koni, perches, springs, suspension, tech, tool
