advice d16z6 head
Old May 14, 2011 | 09:46 PM
ej1noob's Avatar
Default advice d16z6 head
Well i just picked up 95 ex sohc v and 5month later
The headgasket went bad..so now im planning on
Boosting im femiliar w wats coming w that.
But my question is when i was in the process on taking
Off the spark plug 1 came out fine two came off rough and had
Alot of metal shaving around the thread. Now the last
One #4 cyl the park plug smaped and its stuck to the head.
Should i just buy another head or get that fixed??
Miles on motor 140k...
Or should i just buy another and just put all the parts on my
Head to another..??
Im going to boost whats more convinient???
Thanx..
Old May 15, 2011 | 07:25 AM
apexi_rsx's Avatar
Default Re: advice d16z6 head
u can buy another head for 100-120bux if shipped. you can try to get it out. even if the top of the plug snapped off you should be able to put a socket on it after u get the busted pieces out. if ur lookin for another z6 head i have one.
Old May 16, 2011 | 09:00 PM
ej1noob's Avatar
Well the socket end came off and its just the trading part got stuck on the head.
I was told gettn it fix was ok but wont hold for stock turbo
Set up is that true?
If i get the threads fixed and cleaned will it be ok????
Old May 16, 2011 | 10:22 PM
apexi_rsx's Avatar
as far as i know honda's never came stock turbo maybe in the 80's. =oP but if the threads were cleaned out and fixed and hold a spark plug tight i see no reason why it wouldnt work.
Old May 16, 2011 | 10:43 PM
ej1noob's Avatar
Duh 98% dont come in turbo.
Im gna go turbo on my d16 on stock internals.
Just an aftermarket HG.. arp head studs bolts and a super
Good tune..
Tanker17
Jul 16, 2017 08:52 PM
Hadi585
Apr 3, 2014 02:47 AM
Serdar
Apr 28, 2008 08:14 PM
93baggedcivic
May 9, 2007 06:18 PM
1badda
May 10, 2004 06:03 PM
