Installed 4-2-1 header on 93 del sol!!!
ok so last night i bought a 4-2-1 header for 30 bucks and i installed it this morning. Im haveing trouble getn my 02 sensor out of my old manifold. I have a 02 socket that didnt help and visegripes with no help either. I have no money for a new one yet. I have CEL on bcuz of no 02 beign hooked up, and If i run it this way am i gunna have a problem with the car.? There is a 02 in header but not the one i need. Thanks James
well i took it to our shop and tried wd-40 and then put the torch on it heated and tried to get it off and it wouldnt budge then finally it broke. so now i have to buy a new one for 60 bucks.
Run the car for 10 minutes with the o2 on it then try to get it out. Just don't burn yourself. No you won't have a problem, you will lose very small amount of miles per gallon, and your computer will need to clear the fuel maps it learns from that, but that's fixed by disconnecting the negative terminal for 5-10 minutes.
its broken now you say?
amazon has denso o2 sensors for EGs for 36$
http://www.amazon.com/Denso-234-4099...1994&carId=026
96accordlxf22b2
18
Feb 18, 2006 05:22 PM
