Spacers on rpf1s.
Old May 13, 2011 | 06:50 PM
ezcape's Avatar
Default Spacers on rpf1s.
I'm getting some rpf1s, they look alot better with spacers. Was wondering what would be a good length to get? Thanks.
Old May 13, 2011 | 10:18 PM
theEGGmonsta's Avatar
Default Re: Spacers on rpf1s.
what size rpf1's and what offset are you getting?
Old May 13, 2011 | 11:10 PM
TOO MUCH TORQUE's Avatar
i rub already with rpf1 35mm offset, adding spacers will be a disaster
Old May 13, 2011 | 11:15 PM
^ depends on tires too, your tires look meaty though. im running +35 too on a 7.5 wide rim and i dont rub but im running 205/40 tires
Old May 13, 2011 | 11:37 PM
yeah of course, these are 195/55/15 that came off my gsr blades. didnt want to spend money on 205/50/15. next set...
rubs like mad with people in there on right turns. also, my cambers settings are in factory spec, almost 0 degrees.
Old May 13, 2011 | 11:45 PM
yeah i agree with you though...iono it all depends the op wasnt even specific about his height, his camber, what size rpf1s hes planning on...we still have no clue
Old May 14, 2011 | 01:16 AM
lindapaul's Avatar
same problem any help please.........
Old May 14, 2011 | 06:57 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
spec isn't 0 degrees. That's why you're rubbing. If you were at more like -1.5° you probably wouldn't rub.
However I did used to scrape the frame rail seam under the front fenders with 195/55-15. I personally hate that tire size. I'll be going with 195/50-15 for my stock wheels next time.
OP don't use spacers. Get wheels in the offset you want to get the look you want.
Old May 14, 2011 | 11:27 AM
patrick: i never said oem spec is 0 degrees, i said my camber settings are almost at 0 degrees. it ranges from -0.2 to -0.5 on at all corners.
195/55/15 is a comfy size, i personally wouldn't use 195/50/15 because its going to make the odo read too fast. 205/50/15 might be the best compromise.
Old May 15, 2011 | 04:52 AM
Community Builder
Yeah I've had 195/50-15, speedo reads about 5mph fast on the interstate. Helps keep me out of trouble haha
shahriar35
Dec 16, 2014 08:07 AM
mrtrinh
Honda Civic (2001 - 2005)
Jun 29, 2006 04:59 PM
LSegHatchy
Sep 7, 2004 01:42 PM
jweezy225
Jun 27, 2004 09:51 AM
HUBB
28
Oct 6, 2003 10:21 AM
