b20v head gasket dowel pin problem
Old May 13, 2011 | 06:36 PM
Corksil's Avatar
Default b20v head gasket dowel pin problem
hey i have b16 head b20 block.
i need a new headgasket.
i have the dowel pins that make the head and block fit without machining.
do i have to go buy a pre modified headgasket or because i have the dowel pins can i just use the regular oem headgasket without modification...
thanks i don't want to spend hundred bucks on 'modified' b20 headgasket if my dowel pins mean i can use regular local fifty buck head gasket for b20
Old May 14, 2011 | 02:22 AM
Corksil's Avatar
Default Re: b20v head gasket dowel pin problem
come on guys i want to get my car running.
aaaanyone?
Old May 14, 2011 | 05:16 PM
Corksil's Avatar
cmon hondatech
Old May 14, 2011 | 05:29 PM
grumblemarc's Avatar
The Grumpiest
I have to ask. Are you making all of this up as you go? You seem to not have a plan, like you're making this up as you go. It's not like this swap hasn't been done before.
Old May 14, 2011 | 06:35 PM
drzxc1usive's Avatar
you can make your own holes for the dowel pins in a regular HG
Old May 14, 2011 | 07:51 PM
NotAJDMFanBoy's Avatar
head gaskets already have holes for dowel pins. All of them come with dowel pins, just the LS/VTEC uses a different dowel pin.
Old May 15, 2011 | 12:17 AM
B20zEK's Avatar
exactly what he said the dowel pins will go right in i have a b20v and somebody told me that same **** and then they fit right in
Old May 16, 2011 | 07:38 PM
Corksil's Avatar
thanks so much guys.
yeah i have the kit dowel pins from blackworks racing, the stepped dowels, with different sized ends.
i'm tryin to figure out if a oem part store gasket down the road will fit fine because i do have the vtec conversion dowel pins.
do i still need to widen the holes?
sorry if you answerd this i dont quite understand this yet
blackcrx16
Mar 18, 2008 03:24 PM
God-Driven
Feb 6, 2008 05:35 PM
motormike40
Apr 1, 2007 08:14 PM
crv-techu
Mar 11, 2006 04:05 PM
Frank_2.0L
Oct 1, 2005 08:05 PM
