skunk2 intake manifold worth it????
Old May 13, 2011 | 05:44 PM
blacktibby07's Avatar
Default skunk2 intake manifold worth it????
is it worth the money? whos installed it? did u like the difference???
a friend is willing to let go of his for $100, should i?
Old May 13, 2011 | 05:47 PM
owneyboy's Avatar
Default Re: skunk2 intake manifold worth it????
good price go for it
Old May 13, 2011 | 05:48 PM
buster97's Avatar
great price,what mods are done to ur car i have seen some dyno's with no to little improvement on stock b16's(but cant talk by exp never owned one)
Old May 13, 2011 | 05:49 PM
jdm_ek_noob's Avatar
My uncle has one in his eg, he likes.
Old May 13, 2011 | 06:02 PM
24TEN's Avatar
PHANTOM MENACE
Existing mods will make a big difference. I have one on my 91 hatch, SOHC and it makes a slight difference above 7k rpms (my ecu is chipped). It would be pointless if you only have minor bolts ons. Probably be more effective on race prepped heads or turbo.
Old May 13, 2011 | 06:12 PM
killercd4G63's Avatar
If you see yourself going into the High Rpm then it's worth doing BUT for safety sake get upgraded valve springs and retainers. A slight increase in power over the stock manifold depending on what motor you have...
Old May 13, 2011 | 06:39 PM
owneyboy's Avatar
lol... "i have a chipped ecu" ,,, lol its a real good price and depending on motor and mods: will determine how much horsepower increase u will get with the s2 manifold
Old May 13, 2011 | 07:31 PM
4doorteggy's Avatar
if its a b16 i would just save your money and keep the p30 manifold thats on there
Old May 13, 2011 | 07:38 PM
98civdx's Avatar
Master Detailer
For a 100? Yea, I likely would.
Hell, intakes that do noithing cost more.
If you've got other mod's, and chipped ecu, go for it.
Just remember you will need to get the car tuned after, to see the true difference.
Old May 13, 2011 | 09:16 PM
momonimill's Avatar
iv got a shunk2 intake manifold on my b18c1 and it makes a diff. not much but you can tell
Old May 13, 2011 | 11:07 PM
phoxking's Avatar
x2. tune it then you will get a difference, but highly suggest you should have at least full bolt ons with the I.M. then tune it!
Old May 14, 2011 | 02:51 AM
$100 for an upgraded IM is pretty good considering that the standard "bolt-on" on any motor is much more than that Retail. The Skunk2 Intake Manifold goes for $300+ usually.
But i agree with the statement above just for $ saving purposes... Get everything on the motor you can BEFORE you get a tune.
A PROFESSIONAL Tune is the best thing for Any and Every car.
Old May 14, 2011 | 07:07 AM
my car is a D series mini me,(y8 head vtec on y7 block)...
Old May 14, 2011 | 11:07 AM
99civicB20V's Avatar
Got a black series S2 manifold on my B20V with supertech valvetrain. I noticed some top end with it, but I still need to port match it to the head. If you're already swapping it out, get a hondata or similar intake gasket while you're in there.
Old May 14, 2011 | 01:23 PM
Townson's Avatar
That's a deal. Buy it.
Old May 16, 2011 | 06:02 PM
i just bought today!!! need to figure out what the hell to do with all the extra ports on it, major vaccuum leaks....
Old Aug 2, 2011 | 04:57 AM
teggytr's Avatar
Hi, I bought a skunk2 intake manifold and my mechanic said its not going to do much but make the car look good. From his past experience with a del sol, he said that I could run into problems down the road with it. I have a b18b, headers, exhaust, short ram intake and I don't know what to do next? Any advice?
Old Aug 2, 2011 | 04:58 AM
grumblemarc's Avatar
The Grumpiest
Listen to your mechanic.
Old Aug 2, 2011 | 06:10 AM
cvcrcr99's Avatar
If you are not boosted, or running a heavily modified N/A build, it is worthless and will lose power in the lower RPMs. I had one on my y8 with a Crower stage 2 cam, supertech springs/retainers, and the car was powerless until 4500rpms. Pulled it off for a JRSC and the results were much, much better
Old Aug 2, 2011 | 08:24 AM
teggytr's Avatar
If I bought a throttle body and bigger injectors would that make more of a difference?
Old Aug 2, 2011 | 08:47 AM
The Grumpiest
No. This isn't one of those old V8s that you can slap on parts and increases horsepower. Adding all those go fast goodies on a stock engine without benefit of a tuned ECU is a waste of money and can actually HURT performance.
Do research before you start slapping expensive parts on your car.
Old Aug 2, 2011 | 08:52 AM
thenext's Avatar
20% cooler
What if he plans on tuning it?
Old Aug 2, 2011 | 08:57 AM
The Grumpiest
I don't see where he said he was going to get a chipped ECU and have it tuned.
Old Aug 2, 2011 | 09:14 AM
teggytr's Avatar
I am just going to save my money and hopefully buy a turbo.
Old Aug 2, 2011 | 09:18 AM
The Grumpiest
Still have to get a chipped ECU and have it tuned.
