91 civic standard mpfi swap no power to the fuel pump. Please help :)
Old May 13, 2011 | 04:43 PM
furbyiswhatsup's Avatar
Default 91 civic standard mpfi swap no power to the fuel pump. Please help :)
I did the mpfi swap. Had no spark. I bought a new dizzy and wahlah spark! Turned the key over no prime! So I went out got the pump, filter, strainer, an new straps (thought ahead ) and still nothing I am getting power to the main relay I've checked it with my multimeter. But prong 7 (fuel pump) gets no power. It clicks when I turn the key then about 3 seconds later it clicks again. No power to any of the wires under the rear seat either. And I'm only throwing a code 10. Any help is greatly appreciated! Thank you!!
Old May 13, 2011 | 04:54 PM
CylentZc's Avatar
Default Re: 91 civic standard mpfi swap no power to the fuel pump. Please help :)
Try replacing main relay. If its gettin power it should sent power right? just a thought.
Old May 13, 2011 | 05:17 PM
Yeah I have 2. I swith them back and forth. Plus I did the whole test if it's ok with the touching 2 terminals and all that. Everything checks out ok. I just can't figure it out.
Old May 16, 2011 | 09:21 PM
CylentZc's Avatar
Try checking all the wires. make sure they are all okay and not cut open somewhere.
Hightower350
17
May 10, 2013 03:53 PM
brian91accord
Aug 25, 2011 04:18 PM
slow93si
Feb 18, 2007 03:54 PM
swapcrx
Jul 29, 2006 06:59 PM
wpgcivic
Dec 7, 2004 05:44 PM
