Wire Brush, Sand, Prime, Bed Liner! Help me rustproof my frame lol
Old May 13, 2011 | 09:14 AM
Thee_Antic's Avatar
Default Wire Brush, Sand, Prime, Bed Liner! Help me rustproof my frame lol
Thats basically what I am planning on doing this weekend..
The rear quarter panel (Only where it meets the rocker) is rotted out on my 94 del sol, so I'm having a friend help me cut out and weld in some new metal.
While I'm at it, I plan on rust proofing the entire car..its in primer right now so I don't have to care about overspray or anything like that
In some spots there is surface rust starting (Frame only, body panels are fine), so I was planning on using a wire brush drill attachment and getting it down to bare metal, sanding it a little bit to make it pretty (What grit?), and then priming it with some sort of rust inhibitor primer (again, suggestions?), and then spraying it with what will most likely be dupli-color bed liner. I have heard good things about it, but again, opinions on which products are best are much appreciated.
I will be going out to buy all of the stuff tonight so hopefully there are some body guys on right now
Thanks in advance for the help guys
Old May 13, 2011 | 12:30 PM
Thee_Antic's Avatar
Default Re: Wire Brush, Sand, Prime, Bed Liner! Help me rustproof my frame lol
Bump..
I know somebodies killed rust before..this is a Honda forum lmao
Old May 13, 2011 | 01:24 PM
gorillafart's Avatar
your car doesnt have a frame.
Old May 13, 2011 | 01:33 PM
Thee_Antic's Avatar
-_- ....
Fine. I need to rustproof my core supports, sub frame, rocker panels and anything else with ****ing rust.
No one likes a smartass.
Old May 15, 2011 | 03:32 PM
xzodiackillerx's Avatar
evaporust
Old May 15, 2011 | 08:15 PM
Hawkze_2.3's Avatar
Are you going to use a rotisserie?
Civiv3592
Honda Civic (2001 - 2005)
Jun 17, 2017 04:22 PM
h22acd5
14
Feb 2, 2010 12:10 PM
iBrandon
Welding / Fabrication
Feb 29, 2008 06:39 PM
phatboycrxhf
Apr 30, 2007 12:54 AM
adictionbass
Aug 13, 2004 07:15 AM
