Knuckles Si vs. Dx suspension?
Old May 13, 2011 | 08:00 AM
ElCivic89's Avatar
Icon2 Knuckles Si vs. Dx suspension?
So my Si wheel bearing is just going out i happen to have a Dx front suspension will it fit?
Old May 13, 2011 | 08:21 AM
jlicrx's Avatar
Default Re: Knuckles Si vs. Dx suspension?
yes, as long as it is truly a DX and not a Civic STD (4-speed) or CRX HF model
Old May 13, 2011 | 08:53 AM
DCRB's Avatar
dx/lx/si hubs, knuckles, and brakes are all the same. std/hf's use smaller splined axles, and ex sedans have larger hubs and brakes
Old May 13, 2011 | 11:21 AM
ElCivic89's Avatar
good looking out jlicrx and DCRB!!!! wheel bearing noise B-GONE....
Old May 13, 2011 | 03:24 PM
FF for Life's Avatar
I would recommend just putting DA integra front knuckles/brakes on, they're bigger than Si's
Old May 13, 2011 | 04:07 PM
faster Type R's Avatar
or EX knuckles
Old May 13, 2011 | 05:51 PM
CylentZc's Avatar
I am not 100% on this one, but i believe the EX and DA's have the same brake setup. Cuz i have an EX and when i was looking for my new slotted rotors they showed the same rotor for the DA. Correct me if i am wrong tho..
Old May 14, 2011 | 08:50 AM
Tyson's Avatar
EX has the same "brakes" as DA, rotors, calipers, pads. But the knuckles and hubs are different, and have the same geometry as other EF's. DA's are a bit taller and change the camber curve a bit.
Old May 14, 2011 | 06:21 PM
CylentZc's Avatar
Thanks for clearing that up Tyson!
Redline96LX
37
Feb 20, 2012 02:53 PM
nightscream
17
Aug 2, 2011 06:33 PM
ridgeapd
May 27, 2010 04:07 PM
invisible
29
May 3, 2007 08:13 AM
Fatty_1775
Jun 6, 2006 12:32 PM
