Dash Clock Problem *PLEASE HELP*
Old May 13, 2011 | 07:36 AM
JDM_Dyldo's Avatar
Default Dash Clock Problem *PLEASE HELP*
Bought a set of Sir Clocks for my ef
But need the section of the wiring loom that plugs into them
or just the plugs anyone have them?
Old May 13, 2011 | 08:26 AM
mikecp's Avatar
Default Re: Dash Clock Problem *PLEASE HELP*
Doesn't the clock go above the center console?
Old May 13, 2011 | 08:52 AM
DCRB's Avatar
that's not a clock, it's called a gauge cluster. just to clear things up
Old May 13, 2011 | 09:38 AM
JDM_Dyldo's Avatar
Thanks for the heads up
Called 'clocks' here
but could have caused confusion!
Old May 13, 2011 | 10:24 AM
mikecp's Avatar
ahahaha where are you from? LOL
Old May 13, 2011 | 10:53 AM
JDMjUnKieKid's Avatar
where ever your from your going to need the pig tails for that "clocks" and then your going to need both wiring diagrams(for your stock one and the sir one) for the two clusters and cut and solder each one together.
Old May 13, 2011 | 12:32 PM
JDM_Dyldo's Avatar
From Ireland, and trust me, all i need are the bare plugs, wires not needed..
EF9 SiR By the way..
Old May 13, 2011 | 02:07 PM
You might need the pigtails bud, it might have different pins
Old May 14, 2011 | 10:03 AM
Canadian_EF's Avatar
wtf?
technically you don't need the pigtails from the actual cluster. why wouldn't they use the same physical plugs? just go to a junkyard and you might get lucky finding one from another year accord or civic that works.
you can figure out what goes where if you follow the lines on the green wire paper stuff. there will be a ground for all the lights, then power for each one too. it doesn't take lots to figure out, just write down what each one does, match it up to your year, depin, repin.
hell, if you're good enough at depinning, you don't even need to solder. it's not brain surgery.
Jstuneshop
Apr 6, 2006 11:22 PM
Timmay
35
Mar 31, 2005 07:18 PM
Stoich
Mar 20, 2005 05:18 AM
jizzajames
Mar 19, 2005 03:11 PM
EF ridah
Jul 22, 2004 09:25 PM
