acura integra timing problem?
i believe the 90-91 models blink the codes directly off of the ecm which is under the passenger carpet. you jump the service connector after you set the timing belt and before you start the car to set the ignition timing so that it takes the ecms timing out of the equation
yes, correct. does it come on when the key is on II (when all cluster light indicators are on) maybe the person before you removed the bulb.
91akira
Jul 28, 2017 06:38 AM
civic j
Aug 17, 2007 08:10 AM
