2v headunit vs 5v and a 6v amp
basically, old head unit is 2v (Pioneer DEH-3200UB)
new head unit is 5v (in mail)(JVC KD-R900)
amp says "input sensitivity 200mV-6V" (Crunch P1 600.2)
now does the voltage equal quality of sound, loudness, or both? I don't mind if its just quality, but loudness would be a plus as well. I keep thinking my amp with 6v is only getting 2v so i feel like its being underpowered?
thanks in advance!
thanks in advance!
Higher voltage on the low voltage output of a head-unit means much better signal strength at the amp's input stage. Quality of sound really is based on the head-unit it self. If the head-unit uses high end components like burr-brown crystals for the cd player instead of sand based glass and high quality transducers, caps, and so on for the radio side. You can have a radio with 5v pre-out voltage and still be pushing garbage sound to your amp. It helps to have a higher voltage so you can use less gain at your amp in order to match your head-units output.
thanks in advance!
thanks in advance!
There are tons of online resources of how to set the gain. JL Audio has a dumbed down version that is fairly easy to follow.
Well, so far, with the stuff i said i already have, the headunit's max volume is around 62ish (if im thinking right), and I never really pass 40 (anything more and you get distortion in the sound no matter if its amped or not). Then the amp, i turned the level all the way up (bass boost off and freq cut @ 65ish-70) and it puts perfect sound to the speakers, and as ive said before, anything past 40 and it distorts. I was hoping either the new 5v headunit will make the sound either clearer or louder.
0c00l said that the higher voltage lets you match your headunit better, does this mean that it gets louder because you don't need as much gain on a 5v vs a 2v? and thus leaving the amp up high and switch to 5v means it would be louder no? The speaker (JBL P660C) are rated 90rms per side and 270max per speaker (both box, purchased website, and jbl website all say so as well).
amp cranked to max gain, and hitting my 40 spot on the dial (as ive said it distorts after that) it sounds amazing, but it seems like the speaker can handle much more power.
The amp says it will do 150watts rms at 2ohms (which the JBL P660Cs happen to be) and 300 max at 2ohms. It (to me) doesn't feel like 150 watts (more like 70ish)
I was thinking that my amp wasn't using full power since it is rated 6v, i was thinking i was only running 1/3'd the power with a 2v headunit. then on top of that i was thinking 2v would be at the max 62 (distortion area) which means i would actually be running less then 2v which made me thing i was running even less power.....
just trying to figure this **** out, i can build a motor and work on cars but give me voltage and electronics and i have no clue (except computers).
sorry if all this is jumbled my mind runs pretty fast its hard to express myself in words.
Think of voltage like horsepower and current as torque. Having high HP with no TQ is worthless. Your amplifier is a voltage amplifier but also has the added benefit of also providing additional current. The volatage is what makes it loud the current is what allows you tro drive large speakers.
Higher voltage lets you drown out noise. Low voltage system have been used years before high voltage systems. A headunit has many things to do and analog output is just one of those things. Which would you rather have doing your analog audio amplifying? Something that was designed specifically for audio amplification really well or something that was designed to do everything pretty good?
Which was stated
So the head unit (jvc r900) was delivered today and I put it in. Man you are all so full of ****.
2v vs 5v is so much louder. Not to mention higher quality (but that's probably the TI/Burr-Brown 24-bit DAC). I pretty much figured it would be louder so I turned down my amp before I started the car and when it came on, with the amp being on ZERO GAIN, and the headunit maxed, was as loud as my old headunit and yet there was no distortion like my other headunit. Not to mention I was able to actually max the speakers rolling back the power right before you hear the speakers and sounds distort.
Its louder and clearer. Why I ever ask questions anymore is beyond me....
Your amp only has so much output boosting the input source doesn't magically make the amp now more powerful.
If you had an issue you had the gain set incorrectly or you had a crap head unit. Set your gain to max and rock on dude!
Says the guy that can't figure out how to set the gain.
On the pioneer, it had 2v pre outs, and it was only a mid level unit (low end of the mid end i should say). It's max volume was 62, and I noticed without an amp the music got distorted around 40, so 40 was my sweet spot per say. then with the amp hooked to it, I could crank the amp's gain to max still with the head unit at 40 and it would be perfect, but I felt it should be louder.
Then on the JVC, it has 5v pre outs, and its a high end unit. It's max volume is 50, and surprisingly I can take it all the way to 50 with no distortion unlike the Pioneer which would **** out at over 40 some songs at 40. I turned the amp's gain all the way down (basically off?) and at 50 it sounded like my pioneers 40 yet clearer and better sounding.
Now I have the JVC at 30 with the gain up slightly as to be able to turn up louder for some songs, 30 for most, and lower for the other few. Its slightly louder then before (without distorting) and much clearer, I would call it perfection...... LOL. Only thing I need now is a subwoofer (the JVC doesn't do bass like the pioneer and nothing is changed in its settings so its all stock).
MOTOCOMPO
Audio / Security / Video
Sep 23, 2004 09:40 PM
Sam
Feb 1, 2002 09:27 PM
