no power to injectors
Hello was wondering if someone would be able to help me trouble shoot my 94 civic hatch back. i am getting fuel to the rail n getting spark on the plugs but injectors are not opening the plugs are dry. Prior to this i got a boost n someone crossed the cables the computer was screwed so i changed, i do beleave the main relay is done in too, all it does is click. so i got a used one which it does not click so i jumped to pump to a switch and then a fuse to the battery. not sure what to do next.. Is it possible to be a different main fuse thats gone?
i have recently replaced the main relay and it still wont start. i did change the motor now i was told the computer may have to re programmed to the motor how ever the computer i got is for the engine i put i switched engines and computer all at the same time..
first, this is the wrong forum for a 94 civic, so that's likely why there hasn't been much commentary so far here.
the computer should match the engine, or the re-programmed computer should be running the same code as the engine, simple as that.
it sounds like you have more electrical issues that you need to elaborate on, in order for anyone to attempt to help you. you might head over to the EG forums to ask though, as people over there will be more familiar.
always40
Dec 16, 2010 10:10 AM
jay-tec
12
Dec 6, 2004 06:28 PM
