EF civic Need Help!!!!!
Ok, i just installed a b18a1 in my 90 civic hatch i got everything running the way it should except i need help with the reverse lights. i see there is a plug on the front of my s1 trans but i don't know where i would have to connect it to or if i could run it threw the fuse box or something. please help if you could give diagrams if u have them then great but if not that's cool anything else helps.......
If memory serves me correctly, the reverse light switch is a two wire connector and each wire connects independently, should be on the lower part of the tranny. The wires are on the civic harness so you shouldnt have to wire anything up
TypeR0207
Nov 26, 2001 11:31 AM
